We can extend beyond the playing field with our ball-knocker-offer???
Before I have to brief my team about the WRONG path that I led them down and pay the ultimate price (one million dozen Krispy Kreme donuts), I would like your opinion on rule G04 that states
Please let me know what I missed and send all of your extra Krispy Kreme donuts to 555 Pennsylvania Blvd, Houston, TX. Thanks, Lucien |
Re: We can extend beyond the playing field with our ball-knocker-offer???
your question is a little fuzzy - to get the release ball your robot can only reach through the opening infront of the balls - see the playfield drawings in the manual to see what Im referring to
if you hit the release ball by reaching around the opening, deliberately or by wayward auton mode, the small balls will still fall, but you will get a 25 point penalty maybe your students saw that happen, and did not realize they also got a penalty? BTW, your robot can extend out over the sides of the playfield at any point in the game, but if you touch the floor your robot will be disabled for the rest of the match. if that is the best your bot can do - get the ball from the side and incurre the penalty, I guess thats better than not having the balls drop for 45 seconds? maybe? if you cap the goal thats only a 2.5 ball penalty, right? |
But if the “appendage” hits the ball from the outside of the tee frame, a 25 point penalty will be given. I will send you my address for the KKs. ![]() |
I think it's illegal and should cost 25pts. You're definitely extending outside the field and not within the constraints of the bars that contain the 10pt balls.
[edit]To respond to someone's question above. The issue is whether or not it is legal for a robot to extend a flexible device outside the boundaries of the field and drive alongside the field to the 10pt ball. The flexible device would bend at the vertical frame that contains the balls and would thus 'flap' into a ball. I definitely think this is illegal... having anything outside the field is bad. I think FIRST's rule clearly says that the only time you may legally extend outside the field during autonomous is when your extension is within the frame that holds the bonus balls. Otherwise, it's a safety hazard and will cost you 25 points. Team 254's autonomous video does something very similar to what I described above. I'm not sure whether it extends outside the field though.[/edit] Last edited by Yan Wang : 03-16-2004 at 04:09 PM. |
oh wait - I see what you mean
your asking if the restriction is only the vertical pipes? can you reach over the opening as long as you are between the vertical pipes when you hit the ball? oooooh that is interesting - what do they mean by the vertical pipe structure? does that include the horizontal pipes?! |
it says you get the penalty ONLY if you get the release ball that way. other wise if someones auton mode went off a little, and poked at the ball outside the bars, then they would get a 25 point penalty but its ok for your bot to extend outside the field borders in driver mode as long as you dont touch the floor, or reach into the drivers area so why would you incurred a 25 point penalty for doing that in auton mode? that would be unnecessarily strict and would be a double strike against a team whos auton missed the ball by a few feet - the balls dont fall AND they get a 25 point penalty! ![]() |
#7
#8
if the ball IS REMOVED (then you get the penalty) not just if you extend past the field border you are reading more into it than it says |
#9
As it's written: Quote:
#10
so then by your definition, if any part of my robot extends out of the field in my first match, then I get the release ball with that same part in the second match, I get the penalty, because that part extended at some point in the past, so my robot 'has violated the rule'
so everytime I get the release ball in every match after match 1, i get a 25 point penalty, even if i reach through the opening. it should say, if the party of the first part builds a machine, mechanism, device..... I think this thread has gone to the lawyers- as the game was demo'd at the kickoff the intent was clear, you have to reach through, you cant reach around. |
#11
I completely agree with Kris. The reason there is a 'cage' around the bonus balls is for the protection of the referees and volunteers. Although some of those 'flappy' mechanisms aren't dangerous, they still violate the rules by extending outside of the field. There shouldn't be an exception to the rule. If your robot breaks the plane of the ball corral by just an inch, you lose points. Robots that extend outside the field while attempting to remove a bonus ball should be penalized, regardless of whether it was accidental or intentional.
#13
You may only remove a Bonus Ball by using a mechanism that protrudes through the Ball Tee Frame - not around it. (i.e., not from the left, right, or top)
The intent of this is twofold - as a safety rule and to protect the fragile components of the tee frame (sensors and lights). ![]() Aidan |
#15
Here's where the rule is fuzzy to me, and I would like your "insider" interpretation. (BTW, I have seen this happen at competitions this year): A robot starts heading toward the 10 pt bonus ball. The robot extends a small flexible arm off of the side of it's robot. This arm extends beyond the field boundaries. As the robot drives by the Vertical Pipe Structure (VPS), the VPS causes the flexible arm to bend (forcing the arm to go out of the way of the VPS). Once the robot clears the VPS, the flexible arm snaps back and then removes the bonus ball (now the arm is within the VPS). Here is why the rule is fuzzy: Rule: "ROBOT mechanisms used to remove the BONUS BALLS may extend beyond the playing field border as long as they are within the vertical pipe structure surrounding the BALL TEES. If a BONUS BALL is removed from the BALL TEE by a ROBOT that violates this rule, a 25 point penalty will be deducted from that alliance’s final score. " 1) The mechanism does extend beyond the playing field border (outside of the vertical pipe structure). 2) The mechanism is used to remove the bonus ball. (here's the tricky part) 3) When the bonus ball is being removed, the mechanism is within the vertical pipe structure. Here is what is not clear: The rule states that the mechanism may not extend beyone the playing field border unless it is within the vertical pipe structure. Does that mean: a) it can NEVER extend beyond the field border; or b) it can extend beyond the field border, just as long as it is within the vertical pipe structure while removing the ball. Lastly, does the mechanism I describe above violate the rule of not designing a mechanism to purposely react off of the playing field border (because this mechanism uses the vertical pipe structure to deflect the little flexible arm. To be honest, if teams use the flexible arm mechanism, I don't care all that much, but I would like to know your opinion. |
| See the playing field in 3D | Glasses | General Forum | 2 | 06-20-2005 08:57 PM |
| Can we use tape if it contacts the playing field? | archiver | 2001 | 1 | 06-24-2002 01:01 AM |
| Looking for full playing field | archiver | 2001 | 1 | 06-24-2002 12:13 AM |
| playing field updates? | archiver | 2001 | 0 | 06-23-2002 11:03 PM |
| Many inexpensive playing fields | archiver | 1999 | 5 | 06-23-2002 10:57 PM |
