Routine declaration syntax error (Or: Where's wlado?)
Here's a stumper:Code:
char Autonomous_1 (char State) // <---Right Here!
Re: Routine declaration syntax error (Or: Where's wlado?)
That looks OK on cursory examination. What comes right before that line? Is it possible you have unmatched braces?
a lot of times, it will give you a syntax error and the real error will be 10 lines up from the little green arrow.
The only thing above it is comments and #includes
#include "printf_lib.h" /******************************************************************************* * FUNCTION NAME: PrintRamString * PURPOSE: Run 1 loop for autonomous mode 1 * CALLED FROM: anywhere * ARGUMENTS: * Input: char State - What is the state of atuonomous * RETURNS: char - is it finished? *******************************************************************************/ |
Have you modified printf_lib.h?
#7
I added
* ARGUMENTS:
#9
/******************************************************************************* * FILE NAME: printf_lib.h * * DESCRIPTION: * This is the include file which corresponds to printf_lib.c * * USAGE: * If you add your own routines to that file, this is a good place * to add function prototypes. *******************************************************************************/ #ifndef __printf_lib_h_ #define __printf_lib_h_ int printf(rom const char *format, ...); void printid(int data,int crtOn); void printb(unsigned char data,int crtOn); void printd(unsigned char data,int crtOn); void printix(int data,int crtOn); void printx(unsigned char data,int crtOn); void debug_print(char *bufr,int data); void debug_printb(char *bufr,unsigned int data); void debug_println(char *bufr); #endif /******************************************************************************/ /******************************************************************************/ /******************************************************************************/ |
#10
Well, you might be right. I'm still stumped. You didn't do something weird like #defining char, Autonomous_1 or State, did you? (Or parentheses or underscores, taking a lesson from those obfuscated C samples posted elsewhere?)
#11
I'm stumped too...
#12
Since you have an #ifdef/#endif protecting your printf_lib.h from being included multiple times, I suspect the problem is being caused by the line(s) before that #include. Post a bit more context, and look at the other included files for unmatched parentheses or braces or even missing semicolons.
#13
Re: Routine declaration syntax error (Or: Where's waldo?)
After 3 of us working on 4 computers last night to get it to compile, we got it to compile. There were various similar problems throughout the new stuff. I have to ask: Is there a limit on the number af function prototypes in a file?
#14
Is there some reason why you can't use the stock printf lib if it works? If you can't, try remodifying it one change at a time to see what it is.
#15
