Go to Post We owe a lot to Bob (Hammond), he is a true gentleman. - Covey41 [more]
Unread 25-03-2004, 23:14
Alex1072 Alex1072 is offline
AKA: Alex
#1072 (Harker Robotics Team)
Alex1072 is an unknown quantity at this point
Send a message via AIM to Alex1072 Send a message via Yahoo to Alex1072
2 truck drive train
What do you guys think about this idea? The two trucks would rotate independently. The things on the corners are castors; this is so that it won't tip when the trucks are alligned in a straigh line. They can be rearranged more optimally I think, 2 might be enough.
http://www.chiefdelphi.com/forums/at...tid=2028&stc=1
Name:	2 Truck Drive Train.jpg
Alex
President
Team 1072 Harker Robotics
Unread 25-03-2004, 23:25
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: 2 truck drive train
Interesting, but if you are going to have castor supports, why not just have two independtly steerable and powered wheels in the middle and save yourself the trouble of the differential. BTW, if you dont balance your weight carefully, castors can be a real problem because they reduce weight on drive wheels and therefore traction.
Team 1257
Unread 25-03-2004, 23:29
AKA: Alex
Because this acts like a swerve/crab:
it can go like this:
or turn in place like this:
_ _
_ _
and what I like most: because the turning is controlled by truck rotation, you don't have to control motor output carefully to get it to go straight. Just servo the steering trucks. It will go straight or turn like a car. The differential will minimize wheel slip.
Alex
President
Unread 26-03-2004, 05:31
Elgin Clock's Avatar
FRC #0237 (Black Magic)
_ _
_ _
Looks strikingly familiar to THIS!!!
edit: Warning large file!
Last edited by Elgin Clock : 26-03-2004 at 05:38. Reason: Had to add that warning.... :-/
Unread 26-03-2004, 10:26
RoteAugen's Avatar
RoteAugen RoteAugen is offline
None #0138 (Entropy)
RoteAugen will become famous soon enough
Send a message via AIM to RoteAugen
What it sounds like you are trying to accomplish is a 4 wheel ackerman-type steering system. For those of you who do not know what that is, Ackerman steering moves each wheel in porportion to the others in order to make the car, robot, whatever's wheels move on the same radial axis, but two different radii. basically get a centerpoint, then draw two circles inside of each other. the inner circle is the circle the inner wheels will leave, the outer circle is the circle the outer wheels will leave.
the truck idea you brought up would accomplish this, but it would require a very slow, strong motor... but there is a more efficient way to do this. If you have questions, seek out team 138 at the nats and they can show you what it looks like (it uses only one globe motor, and is powerful enough and fast enough to maneuver around the stationary goals and other robots.)
the Hummer mk2 can show much...
TEAM 138 Entropy
we come from the land of the ice and snow....
Unread 26-03-2004, 17:52
Fold em oval!
_ _
_ _
Now draw that again, but get rid of either the right or left set of wheels. I dont think you understood me. A truck does not need to have two wheels is what i was saying. It would be the exact same thing if it had only one wheel, and it would also solve the problem of inner and outer wheels turning at different radii that Rote AUgen mentioned.
Team 1257
Unread 26-03-2004, 19:50
AKA: Alex
If you only have one wheel, the you run into the problem of having to control motor outputs to go straight. I think I might not be understanding what you're saying though.
EDIT: I get it now. There is no inner/outer wheel speed problem because each truck has a differential in the gear box. Having the 2 wheels makes it so that there is no weight on the castors normally. With 2 wheels the castors are only used when you the angles of the trucks get too close to 90 degrees from the robot frame.
BTW I made slight mistake with that ASCII diagram:
the turn in place would look like this:
with castors on the left and right for support
Alex
President
Unread 26-03-2004, 20:12
Fold em oval!
Ah yes, one wheel per truck would cause castors to be used during all movements. Good point.
Team 1257
Unread 26-03-2004, 21:51
RoteAugen's Avatar
now for the real brain-burner:
How to reduce sideways friction on your wheels? (This allows the usage of really fat, high-traction tires with your superior steering system!)
in order to do this, however, the truck idea will not work. why? because if the outer radius is bigger than the inner radius, the wheels have to be at a different curve, no?
there are a few solutions, but I will give you guys the first one 138 used to get you guys thinking in terms of circles
..\______/ ................where ||= the wheel assemblies, and
............................. ___ and \, / = aluminum barstock.
...______
...just pretend the periods don't exist... CD automatically deletes the spaces i had so
now- each of the center bars must move along the same, or initial plane, so they must have a sliding pivot point in the center of each bar. This is what car companies use for the front wheels of their creations.
at each angle, there must be enough slack, or universal ball joints to allow the pivoting of the wheel assemblies.
How to move these simple assemblies I leave to you all to figure out
as I said, if you wish to see a more efficient design, check out Team 138 in the Pits and ask someone about the steering system. They will give you a packet if you are lucky, and it will describe Ackerman steering, and you can see for yourself how we acheive this.... just one thing: DO NOT TAKE PICTURES. DO NOT MAKE SKETCHES. we are very proud and protective of our designs.. but we will not be unkind to you
TEAM 138 Entropy
Last edited by RoteAugen : 26-03-2004 at 21:55. Reason: the periods dont exist... shhh!
Unread 26-03-2004, 21:53
Fold em oval!
The design posted here calls for a differential. A differential solves exactly the problem you describe. I suggest reading about it on howstuffworks.com or something, but essentially, it will allow one wheel in a truck to spin faster than the other, and therefore drive over a different radius. [edit] heres a relavent page http://auto.howstuffworks.com/differential1.htm[/edit] In fact, this is what car companies use to let cars turn.
advanced traction systems use these, but if im not msitaken, they are even more complicated because they allow forcing more power to one output shaft or the other, not just letting them balance out. [more_edit] howstuffworks.com is great, keep reading in that article, they explain this, too. Check out the viscous coupling. I'd like to see some team implement that [/more_edit]
Team 1257
Unread 26-03-2004, 15:06
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
To solve teh weight distibution problem all you would have to do is offset the castors at a slightly different level as the castors.
Really neat idea. Seems that it would be easier to produce that a crab drive is too.
-Pat
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Unread 25-03-2004, 23:26
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
I like that. Very nice design...so many variations of that could be employed and I believe that with a little engineering and development, you could have a first class mobility design.
See you in DC!
Unread 25-03-2004, 23:37
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Would this be like a swiveling chassis like you see on farm and construction equpiment?
I remember a few robots in that past that implemented this idea. I can only find one though, for some reason I'm thinking another one was blue colored.
Just curious.
2002 - 235
Edit: Forget the question I noticed your reply about how it works.
Purdue Alumni
Cummins, Inc.
Unread 25-03-2004, 23:45
tkwetzel's Avatar
Good Luck Teams!
AKA: Tyler Wetzel
Just curious.
2002 - 235
It is similar to 235's design, but much more agile. 235's design has a limited turn radius, because their tracks can not all become parallel. The angle of each set of tracks relative to each other will be the limit on the turning radius for 235's bot. In this design, you can make each set of wheels turn 360 degrees to where you want the positioned. With an unlimited reign of wheel position, you can do point-turns, or swerve. It is a very agile system, that I believe is only beat by omni-directional bots.
See you in DC!
Unread 26-03-2004, 00:20
ggoldman's Avatar
ggoldman ggoldman is offline
FRC #0401
ggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud of
Send a message via AIM to ggoldman
You could just do a drum drive instead of two wheels.
Basically, there is one Drum that powers your robot and it can be turned in any direction. It has alot of traction because it can be made a long length.
For maximum efficiency though, I would just have one set of the truck, because two are not needed for this situation. The only reason why you would need the second set is stability (and the casters handle that).
Looks Good though!!
Gabe
White Paper Discuss: Drive Train Basics CD47-Bot Extra Discussion 6 06-09-2012 11:42
Image Discuss: Transmissions and Drive Train CD47-Bot Extra Discussion 16 17-02-2003 22:11
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
Another chapter in the drive train story AdamT Technical Discussion 19 29-09-2002 13:52
Blowing fuses/tuning drive train DougHogg Motors 10 23-06-2002 00:24
