Go to Post Manual labor experience with engineering training is a powerful combination. - N7UJJ [more]
Unread 28-03-2004, 16:12
FRC #0701 (RoboVikes)
Emerald boa model...
check it out made it this weekend...any comments /critiques welcome...
http://saliksyed.tripod.com/eboa.htm
Team 701
Unread 28-03-2004, 17:02
Lev's Avatar
Lev Lev is offline
#0116 (Epsilon Delta)
Lev will become famous soon enough
Re: Emerald boa model...
Add a slight cellular procedural bump map to the skin so it'll look more detailed.
Also - maybe smooth out the model a little bit - the folds seem to be a litle too sharp, but then i dont know how exactly emerald boa's head looks like.
Otherwise - nice work!
Unread 28-03-2004, 17:43
yeah...i think the folds are too sharp but see when i render w/ light tracer the folds go away and it looks wierd....
the skin texture btw is just temporary i'll probly have an actual bitmap instead of a procedural for the skin..
Team 701
Unread 29-03-2004, 08:39
Lev's Avatar
Lev Lev is offline
LightTracer looks weird because it only leaves diffuse lighting - you dont see any specular highlights. An easy fix is to add some weak point light in addition to your skylight and then render.
Unread 28-03-2004, 18:07
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
You said you used meta reyes muscle system, does that mean that the skin deforms and such as you bend the snake to make it look like it has muscles underneath?
Team 1257
Unread 28-03-2004, 21:14
Yes...but only some muscles...
Team 701
Unread 28-03-2004, 21:22
Fold em oval!
I'd like to see an animation of it wriggling.
Team 1257
Battery charger model# ? computhief263 Programming 3 22-03-2004 13:21
battery model# ?¿?¿ Rickertsen2 Electrical 3 12-03-2003 19:59
Playing field model Leez0r 3D Animation and Competition 9 16-02-2003 14:16
window motor solid model Redhead Jokes Inventor 0 04-02-2003 14:23
3D Model of skyway 20" wheelchair wheel?? Elgin Clock 3D Animation and Competition 2 14-09-2002 16:41
