Go to Post Where's my hammer? I need a bigger hammer. - JaneYoung [more]
Unread 30-03-2004, 14:21
dude__hi's Avatar
dude__hi dude__hi is offline
Now a CSWA
AKA: Cristian Arcega
FRC #0842 (Falcon Robotics)
dude__hi is an unknown quantity at this point
Question auto desk problems
I have been working with auto desk for close to a month, I ran in to a problem. in the assembly file i cant insert a pipe in to a T coupler, a message pops up saying that I have over constrainded something. can anybody help me?
Powerpoint is a distraction, people use it when they don't know what to say...
2008 FIRST Chairman's Award Winner
Unread 30-03-2004, 14:37
Andy Brockway Andy Brockway is online now
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Re: auto desk problems
Are there any constraints on the pipe currently? If there are you will have to turn them off one-by-one and try inserting each time. One of your constraints is in conflict. Sometimes I remove all constraints on the part in question and start fresh.
If the problem is the other end of the pipe then the two end fittings are not aligned and the insert constraint will give you the same message.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 01-04-2004, 21:12
R2K2D2 R2K2D2 is offline
AKA: Raj
R2K2D2 has a spectacular aura aboutR2K2D2 has a spectacular aura about
Send a message via AIM to R2K2D2
This is what you should do...at the bottom left is a tree system that shows all the components and what constraints have been placed on it. Expand the branches that you are trying to constrain together. Then, go through and delete any random constraints that you do not know why they are there. Then try it again. Often times what happens is a user will put a constraint that either they forgot they put or that didn't fully work. Then, they try to apply another constraint and it just does not work, giving you an error. Try this approach, and if it doesn't work, post with more questions.
Unread 01-04-2004, 22:10
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
You could also open the tree like R2 said and look for constraints that have a yellow circle w/ a symbol in the middle (looks like and emoticon almost). The yellow circle basically says that something is wrong or their is an error with the constraint. Delete any constraint w/ one of these on the left side of it.
-Pat
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Unread 07-04-2004, 19:43
DaBruteForceGuy's Avatar
DaBruteForceGuy DaBruteForceGuy is offline
aKa - Steve Bennett
FRC #0125 (NUtrons)
DaBruteForceGuy is an unknown quantity at this point
Send a message via AIM to DaBruteForceGuy
Yea that sounds right... One thing that I do NOT suggest is going through the *sketch doctor* troubleshooter thing that pops-up. It's a waste of time, i would just go through the tree of constraints, highlight them and look atthe veiwing window at the faces that are highlighted... Just use common sense, it's the beauty of Inventor.
Team
810 > 2001-2005 - Student Founder
125 > Present - College Student
---The pessimist complains about the wind, the optimist hopes that the wind will change... the realist adjusts the sail.
***<Therapist> Tell me, is the glass half full or half empty?
***<Engineer> Neither, the glass is too big.---
....Uh, GO NUTRONS!
auto archiving of posts Joe Ross CD Forum Support 4 01-01-2004 02:04
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
picking auto program Mike375 Programming 19 03-03-2003 15:47
Radio problems -- not archiver 2000 1 23-06-2002 22:23
