Go to Post I was considering letting Big Mike bearhug me for the warmth. - Barry Bonzack [more]
Unread 05-04-2004, 16:31
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: Capping 177
Unread 05-04-2004, 16:33
David Bridge's Avatar
David Bridge David Bridge is offline
Totally Sweet... Man
FRC #0177 (Bobcat Robotics)
David Bridge will become famous soon enoughDavid Bridge will become famous soon enough
Send a message via AIM to David Bridge
Re: Capping 177
Not to knock 358 for their brilliant strategy, it took some big balls to pull off (just one really ) but I feel it should be noted for all scouts who may see the picture that 177 continued to herd balls and narrowly win the match
Unread 05-04-2004, 16:41
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: pic: Capping 177
Oooohhhhh...
Big arm.
How'd they do during the rest of the competition?
Unread 05-04-2004, 17:01
EvanG EvanG is offline
Alumni fly-tackle bait
None #0177 (Bobcat Robotics)
EvanG will become famous soon enoughEvanG will become famous soon enough
How'd who do? Us or them?
We went on to win the regional, they however continued to play an excellent game into the elimination rounds where I believe they made it to the semi-finals. However, I could be wrong on that.
Unread 05-04-2004, 17:02
Programming User
Congrats.
Unread 05-04-2004, 17:03
Thank you. It was an amazing day, let me tell you that.
Unread 05-04-2004, 17:04
ZACH P. ZACH P. is offline
Insert Custom User Title
#0321 (Robolancers)
ZACH P. is on a distinguished road
Send a message via AIM to ZACH P.
Hey Evan, you obviously had a reliable ball delivery system for your net. Can you give me some detail on the working of it?
pi is exactly 3
IM me at: zmstr265
Unread 05-04-2004, 17:11
Im not evan, but can answer the question just as well... at the front of the robot we have a knurrled roller thats about 12 inches off the ground, it runs the full width of the robot (about 2.5 balls worth)... The roller is run by a globe motor that has had one set of planetary gears taken out to give us the speed and power that we wanted. The motor is actually anchored inside of the roller so it gives us a direct drive with no loss of power, but at the same time doesnt take up much additional space. In the hopper itself there is a conveyor made of polycord which is run by a geared vandoor motor to keep the balls from jamming... This system results in excellent performance picking up and delivering the balls
Unread 05-04-2004, 17:24
#0321 (Robolancers)
Originally Posted by David Bridge
Im not evan, but can answer the question just as well... at the front of the robot we have a knurrled roller thats about 12 inches off the ground, it runs the full width of the robot (about 2.5 balls worth)... The roller is run by a globe motor that has had one set of planetary gears taken out to give us the speed and power that we wanted. The motor is actually anchored inside of the roller so it gives us a direct drive with no loss of power, but at the same time doesnt take up much additional space. In the hopper itself there is a conveyor made of polycord which is run by a geared window motor to keep the balls from jamming... This system results in excellent performance picking up and delivering the balls
Thank you very much for your response. Know I've just got to figure a way to apply a similar system to our robot...
pi is exactly 3
IM me at: zmstr265
Unread 05-04-2004, 17:32
I don't mean to be the Devil's advocate here, but don't expect to get it right your first time. I will say that 177 has tried several times to do small balls, and it took forever to finally get a system that works. A lot of it is just trying and trying till you get it to work. I'm sure you'll get it eventually.
Also, it's minor, but the polycord conveyer on our bot is actually powered by a van door motor while the basket is currently opened by a geared window motor. This may change and we may be opening the basket with vacuum because its much more forgiving.
Unread 05-04-2004, 18:51
#0321 (Robolancers)
Oh i understand entirely. We have a ball hopper too, and our only proble has always been the delivery of the balls. We played with it all through our regional comp, with limited sucess. Hopefully that will change for nationals. Thanks for your help.
P.S. I dont want to be intrusive, but do you have pics of the system you have?
pi is exactly 3
IM me at: zmstr265
Unread 05-04-2004, 17:14
Programming User
Our team also had a hopper. The hopper itself worked great and we caught 16 or 17 balls every time, but our delivery of them didn't account for the small lip inside the ball corral, and we lost many of the balls.
Oh, well. Glad yours worked for you.
Unread 12-04-2004, 20:57
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
Originally Posted by Texan
Oooohhhhh...
Big arm.
We went to four matches in the quarter finals but were knocked out.
Originally Posted by Ryan Morin
This is great because back in NJ me and my coach, Rob, came up with this exact same strategy but were unable to do cause another robot got in our way. But this is great I thought no one else would ever think of this strategy to stop this kind of robot.
A team at SBPLI Regional approached us to do it to a team there, but something happened and we didn't have a chance to do it. We decided to use it agains 177 however.
Also I'd like to add that 177 really recovered and pushed the loose balls to their human player.
Also, I noticed after that match 177 really made sure this didn't happen again - the drivers would keep the nets closed until a second or two before the balls dropped. Good job guys.
Originally Posted by RBrandy
This happened to us. We almost came back and won the match, but we didn't collect enough balls to over come the other alliances points. It was still a GREAT match. Good job to Team 27 for using that strategy on us.
We decided to drop it because we weren't sure if some of the balls would hit us, then we would be blocking them from falling in - which is against the rules I believe (I'm not positive about that however).
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 05-04-2004, 18:42
RoteAugen's Avatar
RoteAugen RoteAugen is offline
None #0138 (Entropy)
RoteAugen will become famous soon enough
Send a message via AIM to RoteAugen
I love seeing pics like these lol! I definitely want to try to see if we can do that in atlanta... it just looks so funny to me to see one robot capping another!!
TEAM 138 Entropy
we come from the land of the ice and snow....
pic: Panoramic Pic from Nationals 2001 CD47-Bot Extra Discussion 19 23-03-2004 23:38
pic: GM & Simbotics, 1114 -- Simon Capping A Goal CD47-Bot Robot Showcase 11 18-03-2004 15:27
pic: Capping a Robot CD47-Bot Extra Discussion 16 17-03-2004 20:28
pic: Capping a Robot CD47-Bot Extra Discussion 2 17-03-2004 10:17
