Go to Post We don't just build robots. We build people. - Koko Ed [more]
Unread 06-04-2004, 16:55
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Malicous RC Code?
An interesting thought just occurred to me. I was thinking about the VCU regional, all those microcontrollers with radio links sitting around, and the (obvious?) issue came to mind. Would it be possible for a program to replicate via radio link, perhaps through some clever buffer overflow? I'm guessing the answer is no, but it's worth looking in to because:
1) It's technically interesting
2) You'd want to patch that before someone else has a similar thought
NOTE: Yes, I know this would be horrible, I don't advocate this kind of thing. Yada, Yada, Yada...
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 06-04-2004, 16:56
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Malicous RC Code?
I'm gonna find out now...
Thanks for the treasure hunt.
--EDIT--
Or maybe not repicate like a virus. Maybe you could just imitate the OI radio (with a stronger signal, so that you override the real one) and make it appear that the OI is missing, effectively disabling the RC.
Unread 06-04-2004, 16:59
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
The FRC is designed to only download code via the prog port. Though i bet that there could be someway a program could be written to beable to download via radio link. Now the biggest issue is the manual control of a download. Prior to any code being able to be downloaded or stored into the memory, you must first manually press the program button, this activates the firmware for a download. So i do not know if it is possible to force a download via the radio link with people not knowing...
-Michael Dessingue
Unread 06-04-2004, 17:02
phrontist's Avatar
Proto-Engineer
Ah but your missing the key idea here! You don't NEED to download the code! You just need to find a point in the code at which you can overflow a buffer which would allow you to dump arbitrary machine code onto the stack. Thats the idea anyway
Unread 06-04-2004, 17:03
Programming User
Plus, not all computers require you to press the prgm button. If you can find out why, you can overcome that.
Unread 06-04-2004, 17:06
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
There was about a 50/50 split between times we had to press the program button, and times where we didn't. Sometimes we'd just fire up the robot and IFI_LOADER, and the program would go, and sometimes we'd have to hit the program button first. I think the bigger problem is that the RC has its radio channel set in hardware with the little switches, so you wouldn't be able to communicate with any other RC's.
Unread 06-04-2004, 17:08
phrontist's Avatar
Proto-Engineer
Is that REALLY set in hardware? I was under the impression that it was under code control, and that the code simply set it according to those DIP switches. That would be really easy to abuse.
Unread 06-04-2004, 17:09
Programming User
But say you had a radio. You could set it to just scan all the channels that the radios could possibly be on. It isn't that many!
Unread 06-04-2004, 17:12
phrontist's Avatar
Proto-Engineer
Yeah, the possibility of being able to screw up the RC's via radio seems good, but it's really not THAT horrible. What would be far more interesting would be if it actually spread from controller to controller.
Unread 06-04-2004, 17:16
phrontist's Avatar
Proto-Engineer
Originally Posted by Innovation First
The new 2004 FRC Robot Controller (RC) takes the collected data from both the 2004 Operator Interface and the on-board sensors and then processes it using its internal microcontrollers. There are two Microchip 18F8520 PICmicro® microcontrollers inside the Robot Controller. The first is the Master processor which handles radio communications, generates most of the PWM output signals, and oversees the general operations of the Robot Controller. The second microcontrollers is the User processor, and is programmable by the user. The user’s program takes the input data, determines what to do with the outputs to make the robot behave as desired, and sets the PWM and Relay outputs to the appropriate states.
It really comes down to the "Master Processor." Is that programmable? More importantly, is the code that drives it available?
Unread 06-04-2004, 17:17
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
Hello,
To actually program the robot controller is a little bit complicated task. The processors are PICs and don't lend themselves to easy programming. I would love to dissect one of these controllers to see how the programming circuit is wired.
This idea, to try and overrun a buffer in the RC to execute code, not a bad idea. It is a greater possibility. However think about the sequence for data from the radio. The PIC reads the output from the radio (very small packets) and splits it into even smaller packets. Fitting malicious code in tiny packets will be very difficult, at least.
I don't remember if the PIC is a Harvard or von Neumann (sp?) system. However if it cannot execute stuff from the data parts of the processor, overflows will be very hard indeed.
Good luck with your experimenting.
However, I will stay away from u at competetion... =)
btw, the master processor is not normally programmable. And its code is not readily available. I have asked IFI before, and they have refuse, citing the possibility of ignoring competetion commands.
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 06-04-2004, 17:27
phrontist's Avatar
Proto-Engineer
I figured they wouldn't give that up, and thats probably a good thing. The question remains however, whether the "proprietary radio system," could be reverse engineered. I'm (fairly) certain it's impossible to get the actual code from the microcontroller.
Unread 06-04-2004, 18:41
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
That's on the OI. The Controller scans radio channels until it finds one with its Team number (which is set when you tether it). After that, it stays on that channel.
It's as programmable as the user proc. but it's code is on non-volatile ram (Flash, eeprom, etc.). The code that runs it is the firmware update. So if you can decompile it, find a loop hole, and exploit it, you'll be able to make the first FIRST virus!
Yes. It's RS-422. You make a spy cable similar to the one found on BeyondLogic.org.
From not For. Decompile the firmware and the libs.
Remember, the controllers themselves are from Microchip, not IFI. They are probably more forthcoming on info than IFI is.
Of course, the packets are continuous, so it delimits them. This nature makes it very dificult to create a buffer overflow.
And above all, if they catch you, you didn't hear it from me.
Unread 07-04-2004, 01:23
The Lucas's Avatar
CaMOElot, it is a silly place
I believe if you have a programming link (IE serial cable in prog port connected to laptop) to the RC at power-up you don't need to press the program button.
The old Pbasic controller had these modems (EWave Stampers) you could buy to debug and program the robot remotely (very useful, cut debug time in half). I could not get them to work on this year's RC (but they possibly could be modified to work). Maybe Ewave will develop new modems for the PIC RC in the future. If you were to plant the modem on a robot (well a 2003 bot) then you could program it from the stands to do a dance or whatever (would make an interesting practice round).
As for this year, small device could handshake with the program port on power-up and then download the machine code for the aforementioned "Dance Program" from an EEPROM in the device. Now there is an offseason project for you
Disclaimer: I am just kidding and tossing ideas around (like hopefully everyone on this thread). Actually reprogamming a competitor's robot maliciously during a match would probably be the worst violation of Gracious Professionalism in FIRST History. However, it is fun to joke about these things. Come on, Who hasn't proposed an EMP burst bot or Tesla coil bot during Brainstroming?
Robot Inspector
Unread 07-04-2004, 11:29
AKA: Jamie Bliss
Wouldn't an EMP bust the computers running the match? Just wondering: that would be a lot of field errors in a row.
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Interrupt timer, executing code asap? SeanCassidy Programming 10 07-03-2004 01:47
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
