Windows XP Crashing Question
I don't know if anyone else has this problem, but I hope someone has an answer. See, for about the past week, after about 10 hrs. or so of my computer being on, it restarts itself, and when I log back in, I get the "This system has just recovered from a serious error" message box. I want to know if anyone else has had this problem, and if (not) so, is there a fix besides reformatting the hard drive.
I got a Windows XP Home Edition if that explains any. |
Re: Windows XP Crashing Question
First off, how about some system specs?
Have you recently changed any components? Installed any new software? Altered the layout of your funiture (and thus the Feng shui of the room)? Do you have a antivirus and antispyware program(s) running? Bad spyware can cause reboots and system instabilty, espically on certain time intervals when they try to do something 3vil. Random restarts are just a part of computing these days (and if anyone from the Mac crowd trys to tell me they don't have them I'm laughing. Seriously). When it happens over and over again at set intervals, I start to suspect either a piece of software doing something on a timer or a component overheating. -Andy A. |
First turn off the auto restart after failure.
Hit windows key+pause break Go to the advanced tab go to the settings under startup and recovery uncheck the automaticlly restart box in the system failure section Now if it restrts it will stop at the blue screen (if there is one) and you can use it to try and narrow down the problem. |
I installed Avant Browser 3 days before this started happening, and I uninstalled it yesterday, and it still has done it. I don't have any anti-virus and anti-spyware programs installed on this computer, I use TrendMicro's online scanner (works pretty good). Ogre: Thanks, I did that, and I'll see what happens. |
#7
I downloaded it, and now I'm gonna run it. |
#9
As mentioned there could be several issues that could cause this. I saw Andy A's post mentioning a component heating up and it reminded me of a similar issue I had.
One of the computers I have is an AMD-K6 500mhz that was custom built 3 or 4 years ago. The computer worked fine for a 1 1/2 years but then started randomly rebooting. It could do this several times an hour or not do it for a few days. After making sure all the fans were clear of dust, deleting software and swapping out components to no avail I finally removed the fan from the chip, cleaned both surfaces and readded heat sink compound between the two. To this day the computer has never acted up again. I can't say this is your problem but something you might want to possibly check. The suggestion to run the Ad-Aware software is good to. I have it on all my computers. Another freeware program I have on all my computers is SpyBot-Search and Destroy. I don't have a website off hand but it should be easy to find. I found the website for it, link is below. http://www.safer-networking.org/index.php?page=download Last edited by Jay H 237 : 12-04-2004 at 17:45. Reason: add website link |
#11
[quote=Andy A.]Random restarts are just a part of computing these days (and if anyone from the Mac crowd trys to tell me they don't have them I'm laughing. Seriously).[quote]
Can someone from the Linux crowd laugh at you then, because I've had my Linux server stay on for as long as the power will, and I've had my Linux workstation (with rather insane compiler flags) stay on for several days at a time, only turned off because I wanted to get some sleep .As for Windows, I'd suggest trying to get a copy of either Win2k Pro or XP Pro, as XP Home has plenty of it's own issues, at least from personal experience. Another Spyware detector is Spybot S&D, I can't remember the website, but I'm pretty sure it's either on Download.com or a quick google search should find it for you, I use it on any Windows computers I have, works like a charm. |
#12
Hey, thanks everyone for their replies. I'm safe to say no restarts today. I've got Ad-aware and SpyBot both on my computer, and both updated. It's helped a lot on CPU speed also.
#14
Watch out using both S&D and AD Aware on the same computer. If you do noy purge your recovery section of the S&D then Ad Aware will see that as still being on your computer and try to mess with it.
If you have Ad Aware on your computer and you go to run S&D then you will get this message. It's really no biggie - that I have noticed anyways. |
#15
| MIM's question of the day on programming. | Gene F | Programming | 3 | 24-02-2004 16:32 |
| A question about control system options | computhief263 | Control System | 7 | 04-02-2004 14:46 |
| Linux And Windows XP | Raven_Writer | Chit-Chat | 4 | 06-08-2003 18:53 |
| Windows ME | robot180 | Chit-Chat | 11 | 07-07-2003 00:21 |
