Team 535 robot revealed
You've seen the pieces and parts. Now see the total package.
http://chiefdelphi.com/forums/pictur...rrow=4&trows=3 What do you think? Wayne Doenges |
Very nice, one question whats that arm for?
Brian |
Can i use it for thoes stuffed-animal grabber-game-thingys?
![]() J/K It is cool, but i wanna see that arm in operation... |
The arm can place balls in the goal or, more importantly, remove them from goals.
Looks good, Wayne, I am looking forward to seeing it perform. Eric |
The ball grabber is just a little stronger than those carnival stuff animal ones
And yes we can remove balls with it. We can turn, raise and lower at 80 degrees a second. We can, if we had to, throw balls around. Using the FP motors we designed a gear box that looks like an overgrown servo. It should be very durable. Wayne Doenges Beware of TnT!!! ![]() |
when I saw the picture I was pretty sure the arm was built to lift robots
does ball stealing work? |
#7
Unfortunately the arm came in over weight. With everything on the bot, it weighs 183 pounds. So we don't use the arm.
We do take it to the competitions and show it off. At the Buckeye regional we won the Leadership in Control award. On our control board we have a 1/5th scale model of the arm with a glove attached to the end. Wherever the glove goes the arm goes. Just like the mouse on your computer. Also, because of the weight of the arm we couldn't possibly lift a robot. But it would be a site to see Wayne Doenges |
#8
That glove thing is awesome!!!
We tried to do a robot that draws at school, but we didn't have time to develop the glove thing so we used joysticks. Servos are easy fo positioning using a potentiometer, but how did you to that with bigger motors? I know 67 had a similar thing last year. |
| The Death of FIRST | Anton Abaya | General Forum | 23 | 03-05-2006 17:18 |
| How much planning goes into your robot? | Jnadke | General Forum | 41 | 29-01-2006 21:29 |
| More 'Best' Robots (a well thought list) | archiver | 2000 | 2 | 23-06-2002 23:11 |
| Disqualifications | archiver | 1999 | 13 | 23-06-2002 21:53 |
| WASH Palm scouting at the Championship | Mike Soukup | Scouting | 2 | 19-04-2002 15:14 |
