Fischer Price Info
A few questions on the FP motor:
1. What is the thread on the mount holes on the FP motor? 2. What is the exact diameter of the output shaft? 3. If anyone has ever pressed on a new pinion, what size hole did you drill into the new pinion for the press fit? Thanks |
Re: Fischer Price Info
You might want to consult the cad files of the motor http://www.firstcadlibrary.com/ ... you can get dimensions off of there.
The link below may help out.
I am 99% sure it is the same motor we recived in the kits. It may or may not be the same for previous years models (espically those not made by JE). http://www.johnsonmotor.com/product_...?ProdID=130--A -Andy A. |
Ok, thanks guys for the info.
However, the model of the FP motor on FirstCad Lib. doesn't have a tapped hole for the mounts. I'm guessing its a metric thread (the rest of the motor is metric), but does anyone know what it is? |
For whatever reason I can't find the drawing I know I have of the Fisher-Price motor, but I do have the data you need. The hole you need to put in the pinion is 0.123" +0.001". The shaft is a nominal .125" shaft with a knurl (rough lines) on it. The dimension and tolerance I gave you is what I have been using since 2001 (the shafts have not changed). The mounting holes are for M3 x 0.4 pitch screws and are 25mm apart centered on the shaft diameter.
I hope this helps. -Paul |
#7
Exactly what I needed.
Thanks Paul! |
| Blue Man Group FIRST get-together? | Gui Cavalcanti | Chit-Chat | 11 | 16-09-2003 18:11 |
| Module 7 gear -- fischer price motor | archiver | 2001 | 6 | 23-06-2002 22:55 |
| Fischer Price Motor help needed | archiver | 2000 | 10 | 23-06-2002 22:07 |
| Fischer Price Part Number? | bmusser | Technical Discussion | 0 | 02-02-2002 12:26 |
| fischer price motors | Paul Marshall | Motors | 4 | 12-10-2001 09:44 |
