Programming via Edubot
I work as the programmer for my team, but the computer on which I am able to do my work is at home. It would be nearly impossible to bring the robot to my house, so I was wondering if it was possible to download code onto the EDU RC from the computer and then somehow use the EDU RC to download the code to the robot.
Re: Programming via Edubot
Another team member has a laptop that I have used in the past, and we're thinking about getting a team laptop, nothing special but something that does the job. The computers at our school won't allow us to put software on them, but I'm going to try to get administrative access to those, that would be easier.
Also, for our robot next year, I plan to have a removable component which holds the electronics and the RC (similar to 830's this year) and I could just transport this back and forth, at least between the shopa nd the computer lab. Thanks for the responses! |
Yep, your only option right now is to disconnect the RC and take that home for downloading. Aside from the pain of disconnecting and pulling out the RC, you'd just need the 7.2v battery and at least a standard 9v battery to run the RC long enough to download your code changes.
Or a REALLY long cable! Last edited by Mark McLeod : 29-04-2004 at 15:38. |
#7
The RC will resort to the backup battery when the 12 volt supply fails. Since it won't START using only the 7.2v, all you need to do is fool the RC into thinking a 12v source is there at startup. A fresh 9volt battery just touched to the 12v terminals will fool it into thinking a somewhat drained 12v battery is actually being used. That's how we normally started our RC in the pits to drop in program changes when we didn't want to power-up the whole robot, i.e., when the drivetrain was under repair at the same time. Last edited by Mark McLeod : 29-04-2004 at 17:59. |
#9
Yes you can download running only on the 7.2 volt battery because one time while working on autonomous mode I really wanted to download a program but our main batteries just died so we pushed the robot till the drill motor put out enough voltage to start the RC so I could download the program.
#11
That method is even more clever than the nine volt one. ![]() |
#12
I's a long way to go between home and school if you need to make a single code change.
Your project will also easily fit on a standard floppy if you first delete the unnecessary automatically generated files produced by the compiler, linker, etc. (.o, .cod, .cof, .lst, .map) |
| Robot Programming Education | phrontist | Programming | 11 | 03-05-2004 07:32 |
| Fading LEDs using a PWM signal from the Edubot | DanL | Programming | 22 | 30-03-2004 00:07 |
| Programming the IR | James Hine | Programming | 1 | 10-03-2004 14:08 |
| Q&A Discuss: Optical sensors with EduBot | CD47-Bot | Extra Discussion | 2 | 01-03-2003 18:37 |
| pbasic programming | punarhero | Programming | 4 | 21-01-2002 23:32 |
