Go to Post The first was a fish, all silver and spotted. “An opah?” I asked. “Yes,” my friend nodded. I knew not what it meant as I sat there and stared, But I appreciated the thoughts that the posters had shared. - Robotics692 [more]
Unread 18-05-2004, 09:20
Underwater Effect
I am doing a project for school in which i need to create a new book cover to the book "The Pearl". Most people are just drawing theirs, but I wanted to do it in 3dsm. I have my entire underwater scene modeled out, but now i am trying to add an underwater effect to it. I was thinking of just making a plane that is offset to the ground, giving it a water colored shell and setting the opacity so you can see through it. I tried that, but it hasnt seemed to work yet. Either I just get some weird blue streaks going though it, or it looks like the actual sand is blue.
Has anyone ever done anything like this before, and if so, how would I go about doing this?
Unread 18-05-2004, 12:06
Erin Rapacki's Avatar
Erin Rapacki Erin Rapacki is offline
General Manager
Erin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond repute
Send a message via AIM to Erin Rapacki
Re: Underwater Effect
Ask the people who made 'Finding Nemo'
http://www.linkedin.com/in/erapacki
BUZZ 175 (01, 02) - NUTRONS 125 (03, 04) - QUEEN 1975 (06)
Beantown Blitz Founder (04) - FIRST Robotics Conferences (04) - Boston Regional Volunteer Coordinator (06)
Unread 18-05-2004, 12:15
quickie25's Avatar
quickie25 quickie25 is offline
quickie25 is an unknown quantity at this point
volumetric lighting works best
alloy - a mixture containing two or more elements fused together...(ie. A Team)
Unread 18-05-2004, 12:31
Unless you want to add a "ripple" effect, which typically works only when it's a moving picture, I can't think of a simple way to make something look like it's underwater. I'd suggest composing the view so that some of the water's surface is visible overhead, having the light source above that surface, and somehow making the entire volume of the scene filled with a nearly transparent bluegreen color. The "distance blueing" is probably the biggest clue that you're looking through water, but I think a visible "ceiling" is going to help a lot.
Unread 18-05-2004, 13:05
sburro's Avatar
sburro sburro is offline
AKA: Joe
FRC #0663 (crusaders)
sburro will become famous soon enoughsburro will become famous soon enough
Send a message via AIM to sburro
Talking Re: Underwater Effect
I know I know. place the moniter in a plastic bag an sumerge it under water. If this does not work then I do not know what will
Seriosly I do not know. I have never used that program, but when it is done, will you post it? I would love to see it.
Unread 18-05-2004, 20:43
MConte05's Avatar
MConte05 MConte05 is offline
"Operation FIRST"
AKA: Matt Conte
#1098 (G.I.'s)
Team Role: Driver
MConte05 is on a distinguished road
Send a message via AIM to MConte05
Check out this tutorial....
http://64.226.87.40/Tutorials/Undersea/index.htm
Unread 20-05-2004, 16:33
Soukup's Avatar
Soukup Soukup is offline
Animation Guru
AKA: David Soukup
Soukup is on a distinguished road
use volumetrix lighting.
basically you can just add a fog effect to the whole image. And set the density to a very low number. Then use a couple spotlights and point them at the ground and add some volumetric lighting to them. If you have the lights low enough and the fog high enough, if should work out great. Also u can add a couple bubbles by adding a particle array, and then selecting the bubble preset. You can then add a pre-existing raytrace bubble material from the material library and *BAM* a frigging realistic rendering!
soukupd_gv@hotmail.com
Team 74 Alumni
2003 Great Lakes, Midwest, and West Michigan Regional Animation Award Winner
Unread 05-08-2004, 02:22
White_Orpheus's Avatar
White_Orpheus White_Orpheus is offline
Woot for Aphex Twin!
AKA: Chris Teresi
FRC #0253 (MRT)
Team Role: Animator
White_Orpheus will become famous soon enoughWhite_Orpheus will become famous soon enough
Send a message via AIM to White_Orpheus
Try out Dreamscape. It's an excellent plugin for terrain and underwater, if you can shell out the cash.
Team 253
2004 Silicon Valley AVA Winner
Unread 06-09-2004, 19:53
FRC #0701 (RoboVikes)
if you don't want to do that GI lighting thing....
hold on... am i forgetting something.. there is some feature in mental ray that does this kinda light ripple effect .... maybe i am confused...
but this is how to get that ripple effect w/o GI:
then what you can do is make kind of a foot ball shape and clone them so it looks like the picture except covers the entire top of your scene ... make sure that it is kinda above your scene a good bit...
clone this large group and move it up some more and off set it some....
now apply like a 10-20 % opacity to these foot balls and place a light above it with shadows on... aand then you get a nice ocean wavy effect...
i used this in Max 3.1 before cuz i didn't have any
Team 701
Unread 09-01-2005, 20:10
Li Jianliang Li Jianliang is offline
Li Jianliang has a spectacular aura aboutLi Jianliang has a spectacular aura about
I second the fog idea. Use a caustic effect with the lighting also, which would make the ripple-like light effect on the seafloor.
Unread 11-01-2005, 08:55
Baden3DMAX13's Avatar
Baden3DMAX13 Baden3DMAX13 is offline
IUPUI Student/ 3D Animator
None #0393 (Full Metal Jackets)
Baden3DMAX13 is on a distinguished road
Send a message via AIM to Baden3DMAX13 Send a message via MSN to Baden3DMAX13 Send a message via Yahoo to Baden3DMAX13
Ok, I've got some input & some questions... first off are you useing max six, if so you can utilize mental ray to do most of your underwater caustics effects... only thing is this takes a lot of processing power... Ok, for the underwater "look" use the fog effect thing, it works wonders, next for the caustics you can use one of two things, a light above the entire scene that projects a picture of caustics down onto the scene, or thru mental ray. To do it thru mental ray, make a plane above your scene and add a noise and a wave modifier to it to give it that wavey watery look, next go to your renderer by pressing f10 and go down to the bottom to assign renderer, click on default scanline and change it to mental ray. now go into your material editor (m) and change the material to a watery looking material, i'll give a specific one later... assign that material to the plain, now you're ready for the fun part... to add caustics to your scene, select the plain and right click on it to go into it's properties, go to mental ray properties and make sure that generate caustics is selected. Now click ok and go back into your render rollout, go to renderer properties(i think that's what it's called...) and go down to caustics, turn them on... you're almost done, i'll post the rest on here once i look at it and get some values for what you're doing, but without it in front of me that's what i've got off the top of my head :-)
Out of all the things I've lost, I miss my mind the most. - Ozzy Osbourne baby!!!
Fiat 500 (WIP) <~~Check It Out!!!!
Unread 13-01-2005, 08:36
I found a specific texture, you can use a raytrace texture and make it look like water, or use lume glass they look pretty good
Unread 01-02-2005, 21:48
syntaxers's Avatar
syntaxers syntaxers is offline
3dsmax Master
AKA: Chi Feng
#0830 (Rat Pack)
Team Role: Webmaster
syntaxers is an unknown quantity at this point
Send a message via AIM to syntaxers Send a message via MSN to syntaxers Send a message via Yahoo to syntaxers
You could always use a projected caustic lightmap light and add volumetric fog to it.
Like, the light is projecting the image/movie of a caustic effect.
As I recall, there's a nice caustic looping animation in one of the maps directories.
- Chi Feng - Team 830 Forums
Discussion of techniques riley_ag 3D Animation and Competition 11 21-12-2002 17:05
Bad Weather - Better Now than Later archiver 2000 33 24-06-2002 00:39
DC Motor current to an Analog Input junkyarddawg Motors 43 04-04-2002 15:53
