Go to Post Pro safety tip: put a string through coil springs that is tied off securely on the robot frame. This will help prevent the spring from jumping out and killing an inspector if it snaps. - Ninja_Bait [more]
Unread 25-05-2004, 16:08
ModelingMan's Avatar
ModelingMan ModelingMan is offline
ModelingMan is an unknown quantity at this point
Delphi programming help...
Hi, I'm new to these forums.
I need some help, I am making a game trainer in Delphi and having a problem writing the correct value to a processes memory.
Here is some souce:
var
Form1: TForm1;
WindowName : integer;
ProcessId : integer;
ThreadId : integer;
buf : PChar;
HandleWindow : Integer;
write : cardinal;
implementation
{$R WindowsXP.RES}
uses colors, aboutbox;
Const
WindowTitle = 'GTA: Vice City';
Address = 8223480;
NumberOfBytes = 2;
Banshee = 159;
{$R *.dfm}
procedure TForm1.ListBox1Click(Sender: TObject);
begin
If ListBox1.Selected [0] then
begin
WindowName := FindWindow(nil,WindowTitle);
If WindowName = 0 then
begin
MessageDlg('Vice City must be running. Run it now, and then try again.', mtwarning,[mbOK],0)
end
else
ThreadId := GetWindowThreadProcessId(WindowName,@ProcessId);
HandleWindow := OpenProcess(PROCESS_ALL_ACCESS,False,ProcessId);
GetMem(buf,1);
buf^ := Chr(Banshee);
WriteProcessMemory(HandleWindow,ptr(Address),buf,NumberOfBytes,write);
FreeMem(buf);
closehandle(HandleWindow);
end;
What this program will be doing is editing which car is in a garage in game, in that source the car value is 159 but when I run the program it writes the value 22943 which causes the game to crash. I have the NumberOfBytes correct. I think it's something to do with
I would like to get it to write the correct values.
Any help is greatly appreciated.
Unread 25-05-2004, 16:27
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
Re: Need Help? Call us!
This forum isn't really for Delphi programming. We (ChiefDelphi) are a FIRST Robotics team, sponsored by Delphi. These forums are here for discussion of the FIRST Robotics competition. Someone here may be able to help you out, but you may want to look elsewhere for more comprehensive Delphi programming help.
Brandon Martus
e-mail
Unread 25-05-2004, 16:29
I'm not really sure what this is doing in this thread, but here's the problem:
Const
NumberOfBytes = 2;
Banshee = 159;
GetMem(buf,1);
FreeMem(buf);
You're putting a single byte in the buffer, but you're writing two bytes. It looks like the second byte of the buffer has a random (but consistent?) 89 in it. Thus the two bytes written are 159:89, or hexadecimal 9F:59. On a "little-endian" processor, that's the decimal 22943 you're getting.
The solution is to set the second byte of the buffer to zero before writing it. That means you'll have to make your buffer two bytes long, too.
Unread 25-05-2004, 16:56
Re: Delphi programming help...
Thank you for the help Alan.
And I am sorry for the misunderstanding of what these forums are for.
Robot Programming Education phrontist Programming 11 03-05-2004 07:32
Thank you to Brandon and Chief Delphi Ken Leung Thanks and/or Congrats 19 15-12-2003 22:24
Chief Delphi Institute for Better High School Robotics archiver 2000 0 24-06-2002 00:17
Chief Delphi Institute for Better High School Robotics archiver 2000 2 24-06-2002 00:17
Delphi Automotive Systems is now just Delphi... Joe Johnson General Forum 10 21-03-2002 22:23
