Post Requires Login Again?
I have tried posting things in response to other threads. I will login when prompted after hitting the reply button since I usually read as a guest. A number of times, I have hit the submit button only to be greeted with a "You are not logged in" page. When I go to another page without logging back in (ie, clicking on portal), it shows that I am already logged in.
The OS is Win2000 Pro. The browser is MSIE 6.0.2800.1106. indieFan |
Re: Post Requires Login Again?
This is nothing new. The same thing happens with me when I use Mozilla. I don't think you can remain in the post area for too long. Thats what usually happens to me.
So, if I want to write a long-winded response that will take some time for me to formulate, I need to post it part way through and then just edit it?
indieFan |
There is a 15 minute time frame, after that (unless you click 'Remember Me') I think you are logged out. Time it next time, see if its been 15 minutes without any activity. Let me know if this isn't the problem you're experiencing.
| ChiefDelphi Forums Community Bulletin | Brandon Martus | CD Forum Support | 0 | 30-03-2003 23:00 |
| ChiefDelphi Forums Community Bulletin | Brandon Martus | CD Forum Support | 0 | 12-01-2003 22:19 |
| ChiefDelphi Forums Community Bulletin | Brandon Martus | CD Forum Support | 0 | 05-01-2003 22:04 |
| ChiefDelphi Forums Community Bulletin | Brandon Martus | CD Forum Support | 0 | 05-05-2002 22:07 |
| ChiefDelphi Forums Community Bulletin | Brandon Martus | CD Forum Support | 0 | 18-02-2002 01:39 |
