Gas powered engine horsepower equivalent to electrical motor horsepower?
Quick question for anyone who would like to respond.
Is there a way to equivalent Gas Engine Horsepower to Electrical motor power? Are Electric motors rated in Horsepower?? Say a person wanted to replace a gas scooter motor (5HP) with an electric motor? Could this be done efficiently? What else do I need to know to accomplish this? I already have a way to (theoretically) hook the original chain drive to the motor, just need to know what kind of motor I can use to make 5 hp. (Maybe one of the motors from the kit? ) Are any of those equivalent to running 5 HP under load? |
Re: Gas powered engine horsepower equivalent to electrical motor horsepower?
Electric motors are rated in various ways. I've seen them rated in HP, oz-in, Watts and KWatts. Looking at the back cover of my Machinery's Handbook, it says that there are 745.7 Watts for 1 HP, if that helps you. Andy B. |
Maybe you need one of these or these. However, by the time you get batteries and electronics, I think the greatly increased cost and weight show that the gasoline engine is the better choice.
wow...... Stall torque:38500 ozf·in or 34.3hp @72V.... wow...
and stall current at 4 digits??? if only the price were a bit lower.... near the top end of 3 digits is kinda high up... |
If you have a golf cart dealership in your area, you might want to stop by and talk with a mechanic. They may be able to offer some insight on a conversion.
Eric |
#7
just figured I would toss this info in-
The segway has two 2 horsepower motors. They are 3 inches in diameter (I think). The segway also gets the equivalent of 460mpg |
#8
Segway did- I would imagine one way would be to take the price you paid to charge your segway and compare it to the price of gas.
I am not sure how they came to that number but I have seen that number and number in the 200's come out of segway. Quote:
#10
and use those. But.. if this just won't work with the kit motors, then I may just say the heck with it and make it gas powered.:sigh: That's what I get for trying something that's never been done before (as far as I have seen). Maybe there is a reason for that.. |
#11
We put the big black motors on a scooter and it really didnt go very fast... you also had to push off when you started to go.
You also need to keep in mind that engines and electric motors work very differently. If you use an electric motor at peak output power, it is not most efficient! In fact you are converting a lot of the power to heat at that point. Depending on the thermal limits of the motor, you may burn out the motor if you run at this point for a given amount of time. I don't know how long you can run an engine at peak horsepower? Maybe someone knows. |
#13
![]() Last edited by Adam Y. : 31-07-2004 at 17:38. |
#14
Elgin,
Watts is Watts therefore horsepower is horsepower. All motors have different power/torque/RPM curves as they are all designed for different duty. In the operation you are considering, gas power is easier to implement and that is why most designs use that type of engine. There is no control issues other than throttle and no recharge issues other fill the tank. The need to design for output RPM and torque still exists and that is why the transmission is in place. A five horsepower electric motor is not a little toy and the power source is not a little battery. All things considered, the gas powered approach is still the best over all design. |
