Go to Post Bring 'em on, kiddies. You underestimate the power of Amanda Morrison. - Amanda Morrison [more]
View Poll Results: Where did you get your robot's dimensions?
From sketches used for building 112 63.64%
The team measured it after building 21 11.93%
You measured it after building 27 15.34%
Something completely different 16 9.09%
Voters: 176. You may not vote on this poll
Unread 11-03-2002, 21:22
Jan Olligs's Avatar
Jan Olligs Jan Olligs is offline
#0448 (Crandroids)
Jan Olligs is on a distinguished road
Hi everyone,
Just a short question: Where did you get your robot's dimensions from?
A few possibilities as I see them:
- Sketches drawn by component designers
- Team measured everything after building it
- You measured everything after building it
The reason why I am asking is that for me it was supposed to be 1, but it then changed to 3 and the 'everything' is still not true.
I have to admit that my team is not guilty of anything at all, we had a very stressy building phase with a lot of design changes and by now everyone is happy that our robot works just fine (me included).
I have great faith in fools - my friends call it self-confidence. --- Edgar Allen Poe
Unread 12-03-2002, 08:42
Tom Fairchild's Avatar
Tom Fairchild Tom Fairchild is offline
Nice Guy
Tom Fairchild will become famous soon enoughTom Fairchild will become famous soon enough
Send a message via AIM to Tom Fairchild
LoL, if you saw us do our size check at VCU, you would have seen the half inch extra room we have in each dimension. Our bot was obviously designed with that in mind, but we constantly checked while building and changing desings.
~Tom Fairchild~
Unread 22-03-2002, 12:47
Digo's Avatar
Digo Digo is offline
AKA: Rodrigo Ribeiro
#0383 (Brazilian Machine)
Digo is on a distinguished road
Send a message via MSN to Digo
The parts made with laser cut had a dwg original file, so I just imported with inventor. But all the rest had to be measured with rullers and other measuring tools.
And by the way, we used the metric system all the time. It's the brazilian standard (I think most countries' standard too) and so many dimensions had to be converted.
Unread 01-04-2002, 21:52
Jan Olligs's Avatar
#0448 (Crandroids)
SI
It doesn't have to do anythng with the post, but I think that the SI (System International des Unites) is used everywhere except in the US (even in Britain, as far as I know, although they measure temperatures in Fahrenheit).
We had some fun on our robot: metric and imperial system mixed. But we all love Bosch extruded aluminum :-).
Unread 03-04-2002, 01:15
Beowulf Beowulf is offline
Beowulf is an unknown quantity at this point
Send a message via AIM to Beowulf
Re: SI
Oh, yes, 20x20mm extruded aluminum, 35 inches long. Joy.
Beowulf
Unread 08-04-2002, 21:05
Harrison's Avatar
Harrison Harrison is offline
None #0783 (Mobotics)
Harrison has a little shameless behaviour in the past
Measure the robot? What kind of silly idea is this?
Actually our team just made a base frame of 29' x 35'...Then worked up from there.
As it turns out as we needed to loose about 6 pounds we changed it so that it is now about 29 x 30 (or so) and about a foot and a half tall.
Pure luck that it fit.
Harrison Ruess
2002/2003 Team 783 Captain
UOIT '08 Alum
Unread 09-04-2002, 22:17
Jan Olligs's Avatar
#0448 (Crandroids)
Guessing?
It just fit?
How did you do THAT? We took one of the four stripes that come out of the extrused aluminum out; looks very good and sves weight (actually quite a bit).
May SI rule - The silly German guy
FYI: FIRST Robots at the NYC Hall of Science Rich Wong General Forum 9 11-07-2002 10:52
how effective do you think robots going under the bar archiver 2001 4 24-06-2002 00:36
What about prettiest robots? archiver 2000 8 23-06-2002 23:09
'Accidently' ripping other robots apart Vipersna Rumor Mill 6 04-01-2002 23:27
Field and shelf missing dimensions kmcclary Off-Season Events 3 12-10-2001 18:21
