Go to Post I looked at it and originally thought it was a crazy idea... then I looked at it again and it still sounds like a crazy idea. But crazy ideas tend to produce some excellent results. - Yipyapper [more]
Unread 04-10-2004, 10:42
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
Post things to keep in mind while in the pits..
Hmm things to watch out for, look for, plan for:
(Some of these have been said, im just going through everything that I can think of that I’ve encountered)
1) Set screws (make sure they are tightened)
2) electro-mechanical feedback devices are properly calibrated (pots)
I've some bad things happen when you forget to tighten a set screw that attached a pot to the shaft; also, if it isn't calibrated right, I just blame the programmer. (sorry Eric V/Adam B/Mini Taz - and all else I’ve badgered in the past)
3) Plastic shavings/metal shavings - they can get into places they aren’t supposed to...like the exhaust valves for solenoids, causing the valve to stick, or get stuck in a position that is undesirable. Metal shavings and motor controllers, or any other electrical device = bad.
4) Broken pneumatics connectors, cuts in the line, improperly seated line. try to build systems that use pneumatics that don’t come into contact, or close to coming into contact with the connectors (like our plow for 2002) or you might repeatedly break connectors. Latex tubing and some re-shaping was the fix, but try to prepare, and design for that, while the metal part wont break, the plastic parts are not designed to be used as a bump stop.
5)Plastic chain that is "as" strong as steel chain - we had some weight issues, so we tried to use the plastic chain...not only is this chain very expensive...its also "NOT" as strong...we broke the chain in less than ten seconds. Back to the trusty steel chain. Might be good for some applications, but it couldn’t handle the load of our DT. A more brittle material, constant bumping, or other sharp impacts could cause the chain to fail.
6) (Brass) bushing that might not be a perfect fit. Bushings are there for a reason, even with c-clips, if a bushing is aloud to wiggle free, it could cause a lot of damage to the systems it was designed to protect, put a lot of stress on a drive mechanism, or other bad things that could jeopardize the lifespan of a system. Sometimes, it only takes one "event" to kill a system, even if it continues to function, because as time, and the parts wear on. Eventually the system could fail, only takes one initial even to cause a snowball effect.
7) Ok, this is for "Master" miller (those of you, who know me, know what im about to say). Yes, brass is a fine material, easy to machine. Now, I would say that I machined about 15 brass shafts, even though I argued for steel...ok, to the point, don’t be afraid to opt for the stronger material even though it might weigh more...just because the time spent repairing said part might out weigh the added weight.
8)Make sure you have assorted hammers/mallets/50 pound sledge...sometimes, in this field, it is necessary for something called percussive maintenance, don't be afraid to give something a few whacks with the hammer to get it working.you'de be surprised at how fast you can get something done with a hammer, and it is stress relieving.
9)if you have to machine something at competition, and there is a long line, don't be afraid to strike up a conversation with the lone machinist in the shop trailer...quickly earn his trust...and use the machines...because that’s what I did, and I was out of there before everyone else. if you can machine (been doing it for more than 3 years) and your not afraid to take some initiative, then see if the guy (or gal) will let you, you'll be done and outta there in no time, and you can make the part the way you want it, without having to draw it out or try to explain what you want.
10) tighten tighten tighten - always go over the entire robot, and double check, or re-check and make sure everything that is supposed to be tight, is, so that you don’t have a major system just fall off your robot during a match, or even if the part/system doesn’t fall of the robot, the fact that it isn’t properly constrained can lead to other problems. Damaged the drive mechanism and the such.
11) dead batteries, always make sure you have at least 1 batteries fully charged. Also, you should have a millimeter, or you can build a tester designed to just plug into the batteries with the same style connector to quickly check what voltage they are at, which is what we did, works great, and hasn't let us down yet.
12)think about using Velcro to fasten the batteries to the robot, a 1 inch wide strip on the bottom (or more) a few inched long will hold that batteries upside down. I used a 2 inch wide 6-7 inch long strip on the 2002 robot, had to be Hercules to get the batteries out.
13) Make sure all the electrical connections are solid, any loose connections can spell disaster, having a hot wire flopping around with all of your electrics can mean some major work later on. Should always use heat-shrink tubing on the connections so that there is less exposed connections.
14) should test the systems in the pit as much as you can, perfecting them, or insuring that they are functioning, don't be afraid to use white lithium grease (or just wd-40, or whatever you use for lubricating parts) with the drive train, keep the chains lubed, and other rotating parts that might be tight, or stick.
Obviously there are a lot more things, in the past three years I've encountered many different challenges, that really run the spectrum, but I’ll save them for another post. (Note: written on only one cup of coffee...so im sorry for any spellin
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 04-10-2004, 13:12
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: things to keep in mind while in the pits..
Addendum:
No matter how hard you try to block the aisle for saftey when testing something on your robot, (arm, fixed drivetrain, autonomous) a spectator always walks right into your test and a near miss results, if your lucky.
Unread 04-10-2004, 17:35
coreyjon's Avatar
Flight Engineer
yea, what else am I forgetting, say its early morning, and your eating breakfast (in my case, and Boston cream dessert) stand far enough away from your robot, so that in case someone decides to test the arm, it doesn't rip the donut out of your hand, and flings it across the pits. (needless to say, I was not a happy camper.) I'm sure there is a lot of things thats missing here, so, what else is there to plan for, watch out for, remember while in the pits to keep your robot in working order, and the pit crew happy.
Unread 04-10-2004, 20:48
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
For that matter... As long as we're mentioning stuff in the pits, always remember your safety gear as long as you're in your pit. Or doing anything with a power tool. Also, if your robot has a huge arm that moves around above head height, you should probably seriously consider a few bump caps/hard hats in addition to the standard safety glasses, gloves, etc.
Other thoughts:
Roll pins suck. Atleast they do for power transmission. Either the pin is too small and will shear, or the pin will be too big for your shaft, and your shaft will be weakened enough that it will yield. This happened when I let a machinist change the first run design of our tranny last year. After I spent several days machining properly keyed shafts as originally designed, things worked much better.
Also, for securing our battery last year, we used a 2 inch wide velcro strap. It was a long strip of female velcro with a short strip of male on one end and a plastic loop on the other. you wrap it around the battery and some piece of structure in your battery holder area, thread the male end through the loop and tighten it down and stick it to itself. Very strong, very quick and easy to remove.
Try to standardize on one or two bolt sizes and then buy a lot of wrenches and sockets for those sizes. Cause otherwise you'll never be able to find the right wrench/socket/nut/tap/washer when you need it.
Secure your electrical wiring to keep it out of the way of moving parts. One year we had an arm that folded against our chassis near the battery. Predictably, in one round, the battery cable was hooked by the arm as it was unfolding, and our robot rapidly stopped working.
If you have time, make spares of critical parts or parts that are exposed to "vigorous interaction" with other robots. Unless you have made these parts very strong, there's a good chance something will happen and you'll be left scrambling to repair them. Corollary: make these parts difficult to break. Our robot last year had a long arm to grab the chin-up bar. We chose PVC as a material because, while heavier than similarly strong aluminum pipe, it is extremely elastic and bends a lot before breaking. We were wrapped around the pole several times and came out fine.
Unread 04-10-2004, 20:51
Bcahn836's Avatar
Bcahn836 Bcahn836 is offline
Iraq is fun.
AKA: Brad Cahn
no team (Robobees 836)
Bcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond repute
Send a message via AIM to Bcahn836 Send a message via Yahoo to Bcahn836
Be courtious to the teams around you. and keep your teams stuff seperate from other teams gear.
Unread 13-10-2004, 03:50
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Smile Re: things to keep in mind while in the pits..
A few things not mentioned
A) If you can think of 10 things that can go wrong...the 11th one will
B) Keep your area clean and organized. How many times have you needed a tool in a hurry and couldn't find it.
C) Keep the most used tools on your robot cart. Things can go wrong just as you are about compete.
D) If you see a team that seems to be struggling go ask them if you can be of assistance.
E) If you accidentally break another robot during competition be gracious and offer to help them rebuild. Teams will look up to you.
*throws $.02 at kitty, who promptly eats it.
Wayne Doenges
Team 1501
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 13-10-2004, 07:13
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Dont forget the safety goggles... as i pointed out before in another thread... only a few days ago... the safety goggles saved my eye...
Unread 13-10-2004, 08:32
coreyjon's Avatar
Flight Engineer
yea, good mention of Murphy's Law, this year I'm counting on the robot stealing my donuts in the morning, and planning accordingly. On a more serious note, I'll have to repeat: Organization in the pits. If you aren't organized and you can't find the tools you need, then you can't perform the tasks at hand. so while last year I was in charge of our pit (title: Pit Master Chief as well as the lead mechanic) it was one of my duties to insure the pit was clean and organized (as far as the tools and supplies directly related to the robot). This year I am a mentor, so I guess I'm supposed to try and teach people what I've learned over the last few years. It's gonna be hard to watch from the sidelines as this years robot gets built. Although I may get props on designing the gearboxes this year. JVN (I'm about to make a shameless reference to highlander) "There can only be one"! just kidding john. I'm looking forward to seeing the goods from Clarkson's team this year, Hopefully I will be in charge of the transmissions, I have spent many hours designing, and making things interchangeable,(yea thats right, bringing in interchangeability for added flexibility) but the fact is that me designing this years gear boxes is not a sure thing (yet)(but I hope I get to use some of my designs). Time to train a small army of younger kids, and then they could build it. 0000 I like the idea of having a small army..
Unread 13-10-2004, 08:38
RoboMom RoboMom is offline
people expediter on Team Kluge
AKA: Jenny Beatty, no relation
no team (they are all my teams)
RoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond repute
These are terrific suggestions. If someone or a group is up to the task, these could easily be abbreviated and listed, like "Hints for in the Pits" along the lines of "18 Hints for Rookie Teams" that NEMO put together for a one-page handout (see the white papers for copies.) It would be great to be able to hand out things like this at kickoffs, etc. as there is a lot of practical information here.
I would be willing to help but don't want to take this one solely.
Co-Founder of NEMO (Non-Engineering Mentor Organization) www.firstnemo.org
Volunteer Director, STEMaction, Inc. www.stemaction.org
FIRST Senior Mentor: Nov. 2004 to June 2009: "Experience is that marvelous thing that enables you to recognize a mistake when you make it again"
This is How I Work: http://www.chiefdelphi.com/media/papers/2862
Unread 13-10-2004, 08:53
coreyjon's Avatar
Flight Engineer
I would be willing to help, I could come up with an abbreviated version of all the ideas on here, or at the very least help to produce something to hand out like you've suggested.
Unread 13-10-2004, 09:08
Take a look at the NEMO hints format and then just start listing the ideas (offline). Try for just one sentence or two for each. They can be edited later. Keep adding ideas as they get posted and keep track of the post-er and team.
I think this will be much appreciated by all, especially the rookie teams.
Unread 13-10-2004, 09:11
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
I'm surprised this hasn't came up.
When at all possible try to keep isles clear. The isles are not the place for lawn chairs and picnics. Sure you many stop and have a conversation but I'm talking having robot carts, robots, and other large things just sitting in isle.
Also arrange to have a pit crew if you have a large team (a normal amount would be 4-5). That way only the pit crew is in your pit and you don't hang out into the isle and it will be a lot easier to fix the robot or get things organized
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 13-10-2004, 15:07
Ted Boucher Ted Boucher is offline
Its been awhile.....
FRC #0237 (Black Magic Robotics)
Ted Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond repute
Alittle off topic but along the same lines:
Also, it is a very good idea that you do a system check once you get to the field during a regional or championship competition. Things can happen from the pits to the field and ruin your match. Also, it is good to have a system preparation battery on the robot in the pits and change to a fully charged battery at the last moment at the field so you don't have any battery failures.
Wire tires are also a good way to hold a battery in the robot. This year we had 2 strips of Velcro (3/4 inch wide) and failed almost every time during a big wreak. Since then we backed up the Velcro with wire ties and they usually did not fail.
Also, alway have your batteries charging! It is a great idea to assign someone the job in the pits to always monitor your batteries. Batteries can make a big difference.
Unread 13-10-2004, 16:03
Post your team’s Match times, so you stay on schedule in the pits. A lot of teams use small white boards for this purpose.
Keep an area for programmers to work and plug-in (I keep finding tools and metal shavings on top of my laptop).
Assign a Pit Chief to be responsible for:
vKnowing where all tools and spare parts are stored and keeping them that way.
vMaintain a list of items to be purchased, supplies to replace, etc.
vTrack tools and parts borrowed from FIRST and other teams (the Pit Chief can write thank you notes in his or her spare time) and tools loaned to other teams .
Unread 21-10-2004, 18:46
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Originally Posted by Mark McLeod
vTrack tools and parts borrowed from FIRST and other teams (the Pit Chief can write thank you notes in his or her spare time).
Ooooo!
I really like that one!
I think 229 owes a few hundred (thousand?) thank-you notes.
Good Idea Mark,
John
True things heard at college. Billfred Chit-Chat 46 07-11-2005 15:21
Robots that stood out in my mind... archiver 2001 1 24-06-2002 03:23
Bored out of my mind!!!!!! archiver 2000 3 23-06-2002 23:08
Suggested list of things to bring to the regionals Andrew Wyatt Technical Discussion 1 06-03-2002 14:41
how do u hook up things through the fuse panel? chrisw Technical Discussion 9 12-01-2002 19:51
