Hey guys,
I am a team member of the Chantilly Robotics team(team # 612). We needed some help from you guys to get started in programming. Last year I was in the mechanical team, so I don't know about programming. This year we do not have anyone experienced in out team for programming. The thing is we have many people expert in C language. They know how to program well. But we don't know how to get started. Like simple questions - Where do you get basic programming code from, or how to download programs from computer to the robot controller, or which IDE to use,... So I was wondering if you guys can tell me the basic. We can figure out the actual programming stuff, but we need to get started first. Last year I got very good help from you guys in mechanics. So I hope I will receive the same kind of help this year. You can reply to this post, or email me on suchitligade@hotmail.com Thanks, Chantilly Team Member. |
Re: Help needed for getting started!
Pretty much the best bet is to read through http://www.innovationfirst.com. There's so much information there, it makes my head spin.
I'm assuming you have installed the IDE, compiler, and IFI_Loader (the CD with the horrible green interface). If you havent, then do that.
When thats all done and the code is all downloaded, open it up and go to the "user_routines.c" file. From there, find the function "process_data_from_master_up" (or something like that). It has a call to "default_routine" in it. That would be the best place to start looking. If you have any more questions, post away! PS: I hope the names are right, I'm just doing it from memory... |
Also, make sure to upgrade the IFI loader from version 1.05 to 1.07. You will skirt many a problem if you do this right away. I believe the upgrade is available at the Innovations First link in the post above.
To sort of condense things ...
Beginners need the following to program the FIRST robot: v FRC RC Default Code v Microchip MPLAB & C compiler v IFI_Loader v A standard serial cable v A computer with a serial port or USB-to-serial converter
| The Grand FIRST team.. programmers and others needed | randomperson | Programming | 0 | 31-05-2003 23:46 |
| Weight needed to tilt bridge... | archiver | 2001 | 4 | 23-06-2002 23:43 |
| Battlecry 3 volunteers needed? | Hymnson | Off-Season Events | 4 | 02-06-2002 12:38 |
