Go to Post That's just the thing about plastic or brass gears; they tend to morph into plastic or brass washers real fast. - Nick Seidl [more]
Unread 16-11-2004, 17:02
kc8nod's Avatar
kc8nod kc8nod is offline
AKA: Ted Hansen
FRC #1216 (Knights)
kc8nod is on a distinguished road
2005 Kickoff broadcast
Has it been confirmed that the Kickoff broadcast will be on NASA TV? I'm trying to set up a place for my team to watch the broadcast since we can't all go to our local remote kickoff.
If it's not going to be on NASA TV will FIRST publish the broadcast information so that folks with satellite receivers can tune in?
Unread 16-11-2004, 17:14
Re: 2005 Kickoff broadcast
http://www.usfirst.org/robotics/2005/remotekickoffs.htm
http://robotics.nasa.gov/first/2005/kickoff.htm
Unread 16-11-2004, 17:22
kc8nod's Avatar
AKA: Ted Hansen
FRC #1216 (Knights)
Originally Posted by Joe Ross
That's just what I was looking for.
Thanks
Unread 04-01-2005, 09:20
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
how does one see it from the UK?
i found this link
http://robotics.NASA.gov/first/2005/kickoff.htm (as you said up there)
but I'm worried by the fact it says
- Watch the 2005 First Robotics Competition Kickoff Archive -
the archive being the worrying bit.... anyone know if this is definitely going to be watchable live here? otherwise could anyone please provide details of a stream, as we will have a 2meg connection to watch it from on the night, if we know where to watch from.
Thanks In advance
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 04-01-2005, 09:42
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
I have Direct TV, and when I look at the NASA channel listing for that day (channel 376) at 10:00 it just says "this week at NASA video file" and no info about FIRST. Does that mean I actually have to have my kid go outside and hold the dish on those coordinates to pick up a "different" NASA channel than the Direct TV one, or does NASA not report the showing info correctly?
www.179swampthing.org
Unread 04-01-2005, 11:41
Elgin Clock's Avatar
FRC #0237 (Black Magic)
The TV listing on NASA Channel is never accurate. For The past 3 years, As long as it is on NASA Webcast (Live on 2004-1-8, and then Archived Denman), then it is also relayed on NASA TV. If you have Direct TV, and you have the oval dish, and you get NASA TV, it should be on there. If you have Dish Network, you don't need a special Dish, and NASA TV is channel 213 (last I checked - about a month ago).
If it is on NASA Webcast, but not NASA TV, I would be truely shocked, and maddened by this since I record the webcast for my team every year.
Enjoy the show!
Edit: By the way, there is a delay in the NASA Webcast, I believe behind the NASA TV Channel feed. I believe it is a couple minutes, or about 5 minutes maximum. I know there is a delay, just don't remember how long of a delay, and which feed is behind which. (NASA TV, or NASA Webcast)
Unread 04-01-2005, 14:50
Dr.Bot
Posts: n/a
Delay in webcast.
SInce we use real media or windows media in webcasting there is a minimum built in buffering delay of 15 to 30 seconds. Depending on numerous factors (connection length of braodcast, number of viewers) The buffering delay can be longer. In theory it shouldn't be more than a minut or two, but a couple of years ago I heard one unconfirmed report of a 1/2 hour.
Don't panic - If you miss the live webcast, the archive will be up by Monday if not before. We are doing things a bit differently this year and using the NASA Portal for the primary webcast. The internal older NASA SAVIG network will be used as a backup. All webcst sources will be listed on
REP
Unread 04-01-2005, 14:42
i found this link
Thanks In advance
The archive is just that, an archive. On the day of the broadcast there will be a link to watch it live.
2005 Kickoff: Who's going? Billfred General Forum 54 18-12-2004 15:56
[Official 2005 Game Design] OK, so YOU design the 2005 game... dlavery FRC Game Design 37 26-10-2004 23:15
Your Thoughts on the 2005 Championship Eligibility Criteria! dez250 Championship Event 57 10-09-2004 14:59
Qotw [11-17-02]: Manchester or remote kickoff... Ken Leung Rumor Mill 19 09-01-2004 16:18
Hints @ Kickoff Broadcast Nate Smith General Forum 13 05-01-2002 10:14
