Need help Importing Autocad >DWG files
I am using Autodesk Inventor R4 and when I try importing the Drill Motor Transmission Mount Autocad .DWG into a drawing file
I get a blank drawing. Can anyone help?? |
heres what you do...
if the autocad drawing is a 3d model: open inventor.. goto the add-in manager and turn on dwg then make a new part and import in the dwg solid. THen you can make a new idw with the model in inventor Gabe |
Add-In manager
OK?? the add-in manager does not list dwg to turn on
It has DSS Monitor Add-in and Fasteners listed |
| Importing inventor files to 3ds max.... I found it!!!!! | Tyler Olds | 3D Animation and Competition | 0 | 21-01-2003 19:16 |
| Multiple files usage | punarhero | Programming | 2 | 12-01-2003 11:45 |
| AutoCAD Viewer | Gadget470 | OCCRA | 2 | 25-09-2002 03:19 |
| AutoCad compatibility | archiver | 2000 | 4 | 23-06-2002 22:51 |
| AutoCAD, Inventor, or Other | D.J. Fluck | General Forum | 23 | 31-12-2001 08:59 |
