Running the robot using Infa Red?
An idea came to mind while I was sitting here just looking at my PPC, controlling the robovation bot using IR, but is this even possible? Maybe not for the actual competition *It can't...I'm pretty sure* but for an...extra outside kind of thing? Could it be done?
I would need the reciever on the bot, and the PPC can reach 30feet, if I need more I can build a larger sensor thingy *I'm not in the state for technical words, 8 hours of sleep in 2 days* But the software for the PPC would have to be programmed, and would it even connect to the robovation computer? Just a...thought that might be cool to explore. Thanks for any help |
Re: Running the robot using Infa Red?
I know there are infrared modems with serial connections. Plug one in to the Robovation controller, and figure out how to communicate with it and you should be able to read data sent from any compatible IR device.
-Kevin |
Ah, that's even easier. No need to buy new parts. Mr. Watson, do you know if these two beacon waveforms are used in IR modems in laptops and PDAs to transmit data?
-Kevin |
I have a lot to look into, but before I do, I want to double check on something...I can't use IR for the competition to control my robot...correct?Even if I can't, I could just build the desired circuit from you're links on you're site, but I didn't get any of those parts in the Kit...so what happens now? It all looks interesting, I have some reading to do ![]() |
#7
-Kevin |
#8
| How much planning goes into your robot? | Jnadke | General Forum | 41 | 29-01-2006 21:29 |
| what kind of robot will win? | Bcahn836 | Championship Event | 44 | 12-04-2004 00:02 |
| YMTC: Bluabot sits on Redabot | Natchez | You Make The Call | 19 | 08-04-2004 16:43 |
| Beatty's 2004 Robot | mzitz2k | General Forum | 81 | 26-03-2004 15:18 |
| about how Drive Train push the robot... shouldn't the force accelerate the robot? | Ken Leung | Technical Discussion | 12 | 26-11-2001 09:39 |
