Go to Post That tetra has personality! - Kevin Thorp [more]
Unread 05-01-2005, 21:11
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
sketching onto revolved surface
i wish i had time to attend either of the inventor live sessions, maybe someone who did get to attend could help me out.
i'm trying to add a feature, not unlike a slot onto a previously revolved surface.
i wish to sketch the feature then extrude it through the part! any help would be appreciated. thanks.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 05-01-2005, 21:29
Sean Schuff's Avatar
Sean Schuff Sean Schuff is offline
Year 18 in FRC!
FRC #0093 (N.E.W. Apple Corps)
Sean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond repute
Re: sketching onto revolved surface
If you're looking to extrude/cut a simple feature through your part, the following steps should do the trick.
In the model workspace create an axis through the center of the revolved object. Once you've created the axis, create a work plane on the axis and select which plane (XY/XZ/YZ) you want to apply the work plane to. Once you've created the work plane you can select it and select the "sketch" option to make it a sketch plane. Now sketch whatever profile you want to cut out of the object, finish the sketch, and perform an extrude/cut on the part model.
* Note: If you leave the sketch plane on the axis of the revolved part you can use the "slice graphics" option (right mouse click in the sketch window and select "slice graphics") for easier sketching of the feature.
If you don't want to create a feature that is cut all the way through the object you will have to offset the work plane by dragging it away from the work axis and entering an offset distance.
Try this out. If it doesn't work, PM me and I can give you more detailed directions.
Good Luck!!
Every child. Every program. Everywhere.
Thanks Plexus Corp. for two decades of partnership and counting...your company gets it!!
www.nacteam93.com | Tesla Engineering Charter School
Unread 05-01-2005, 22:10
AKA: Anthony Lapp
i sent you a pm....just a few more questions! thanks.
Anthony Lapp
RobotOpen
Unread 05-01-2005, 23:14
Collmandoman Collmandoman is offline
Post-A-Holic
Collmandoman has a spectacular aura aboutCollmandoman has a spectacular aura aboutCollmandoman has a spectacular aura about
I can also help you if you need it =)
NJ team 41 would like to test on official surface Smrtman5 General Forum 1 16-02-2004 19:07
Dimension Wanted - BOM Caster: floor to top plate surface height kmcclary Kit & Additional Hardware 2 28-01-2004 12:02
Metal can touch the playing field surface. Madison Rules/Strategy 3 02-03-2003 00:31
