Go to Post The Championship, The Championship Event, The World Championship, The international Championship, Internationals, Champs, Nationals, Nat's, ATL... I just call it the best time of my life. - Kyle [more]
Unread 06-01-2005, 20:36
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Question How do the Analog Inputs work?
What do the analog inputs measure? (voltage? resistance?) I'm assuming voltage, but I don't know if I'm right. I am a newbie so I don't know much about the brain, but that is my job. I'm trying to make IR sensors to detect which angle the beacon is in relation to the 'bot. Please help.
Aren't signatures a bit outdated?
Unread 06-01-2005, 20:42
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Re: How do the Analog Inputs work?
There are analog inputs on both the OI and the robot controler, I am assuming you are asking about the ones on the Robot controler.
They measure voltage, have 10 bit resoultion, and a 0 to 5 volt range, you can code to drop the resoultion to 8 bits. Full info on how to code and such can be found in the progamming instructions and by searching the fourms here.
Good luck Biff
Unread 06-01-2005, 20:53
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
Smile Re: How do the Analog Inputs work?
Good luck Biff
Thanks, I wanted to confirm my suspicion.
Unread 07-01-2005, 00:11
There are two different questions here. Biff answered about analog inputs, however, that doesn't help you get the IR beacons working.
The IR beacons emit IR pulses at a specified frequency. In essence, they turn on and off at a specific rate, a digital signal. When you see the beacon, you see that frequency, otherwise you don't see the beacon. If you want to find the beacon, you must rotate your sensor until it detects the frequency. You can do this by connecting it to a servo or motor, or you can rotate your entire robot.
Kevin Watson has posted some example code for handling the IR sensors. http://kevin.org/frc/2004/frc_tracker.zip If you want to see all of his neat programs, his main site is http://kevin.org/frc/
His code uses 4 infrared sensors and 2 servos. If you don't want to get that complicated, you should at least look at how he detects the signal.
Why not analog sensors?? gnormhurst Programming 16 07-03-2004 16:14
Pneumatic Layout (Does it work?) Matt Fultz Pneumatics 14 04-02-2004 14:56
Who knows how the motors [I]really[/I] work? Wetzel Chit-Chat 5 13-02-2002 21:50
Does anyone on this board work at home depot? mnkysp6353 General Forum 2 30-12-2001 13:27
