Arm Designs
I know there is a very similar thread already out there, I just wanted to get some input specifically related to the arm design. What kind of design would work better, fork lift or a bending arm? Ideas? Post away.
Re: Arm Designs
Re: Arm Designs
Re: Arm Designs
Re: Arm Designs
This however, only removes the need for a counterweight, and if I hit you with your center of gravity really high you're going to go a-tumbling. |
Re: Arm Designs
Forklifting can be worked nicely as can an articulating or telescoping arm. But why would some one on 177 mention that?
The history section of our website should inspire some of you. http://www.swindsor.k12.ct.us/Highsc...s/clubs/first/ Pete Last edited by Peter Matteson : 09-01-2005 at 20:39. Reason: Added weblink |
#7
Re: Arm Designs
I think using the arm is better since you can grab the tetras anywhere around the robot; whereas, the forklift requires you to be in a specific position to grab them. However, with an arm, it's harder to control your robots balance n might tip over, but you may be able to use your arm to pick yourself up.
#9
Re: Arm Designs
What specific arm designs would probibly work best for manipulating the Tetras?
#10
Re: Arm Designs
The teams ive been on have done both an elevator system and a stereotypical arm design. Both have worked to some extent. The standard arm design is easier to design and build, but i feel the elevator design is the easiest for the drivers to handle. The most important factor in the design is ultamately how much thought and detail goes into it.
#11
Re: Arm Designs
Re: Arm Designs
One thing about being a 14 year team is you get to see alot of previous design that could work with this year's game and I think we found a good one today.
#13
Re: Arm Designs
it depends on the chassie but my preference is a lift because it doesn't move the cg out it just moves it up a little. that is just my opinion.
hope u do well see u at the comp Last edited by Phenix : 10-01-2005 at 22:52. |
#14
Re: Arm Designs
For arm design I was tossing around the idea of something similar to a bucket truck arm (that's a bending arm isn't it?). My team hasn't taken much fancy to it but I think that it could give a lot of flexability in motion when the tetra is so high in the air.
Here's an Example of what I was thinking (This isn't a robot picture, just an idea). Just my thoughts though ![]() |
#15
Re: Arm Designs
After my earlier post I took some time to think and came to my senses: an arm's the way to go. If you've got a forklift then you need to be right next to a goal to score, so a robot could just get between you and the goal. But if you've got an arm you can reach over another robot if it's in your way. The hard part is going to be designing a mechanism for the end of the arm to effectively pick up and score the tetras.
| Designs that would never work... | Cyberguy34000 | Technical Discussion | 60 | 09-01-2007 20:56 |
| Manipulator designs | Max Lobovsky | Technical Discussion | 10 | 27-01-2005 07:43 |
| Reflected Inertia? | archiver | 2001 | 9 | 24-06-2002 03:50 |
| Controlling Arm travel - Limit Switch or Mechanical Stop? | archiver | 2001 | 8 | 23-06-2002 23:55 |
| telescoping arm & ten second rule | Ben Mitchell | Rules/Strategy | 4 | 18-02-2002 21:37 |
