Go to Post A clean pit is a happy pit, a clean pit is a controlled pit, a clean pit is a safe pit. - DjAlamose [more]
Unread 09-01-2005, 19:14
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Is this the new scripting code?
http://kevin.org/frc/
First link there
Found the site while browsing through another thread, and I'm fairly certain that thats the code for it, not sure how it gets the command from anywhere, but that seems to be parsing them.
Unread 09-01-2005, 19:21
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Re: Is this the new scripting code?
Assuming that the first description says this, I'll have to say "Yes, it is the same code!"
Raw build directory of the scripted navigation demo shown at the kick-off. An updated version is in the works.
Unread 09-01-2005, 19:25
Rookie Year: 1234
All the commands + descriptions are in robot.h in that file, as I understand it you put those into the matrix in commands.h, with any paramaters, from there the stuff in robot.c takes it line by line and executes functions based on what you did there. Its a pretty simple system, but it can probably get pretty powerful later on
Unread 10-01-2005, 01:25
Kevin Watson's Avatar
La Caņada High School
FRC #2429
First link there
Yes, this is a zipped-up copy of the build directory for the code we demo'd at the kick-off. As we finished the code the night before the kick-off and we needed to get the code to the FIRST IT guys ASAP, we (Rich Petras and myself) zipped-up the code and sent it off just as the kick-off ended. Hopefully FIRST will post it somewhere in the near future. In the coming days I hope to polish the code a bit (the gyro code is still rough) and start posting updates.
Kevin Watson
http://kevin.org
Unread 10-01-2005, 07:18
Hieb Hieb is offline
Hieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to behold
Were the 'bots at the demo made with the kit sensors then? The accelorometer and gear tooth sensor (Hall Effect sensor)? Or were quadrature encoders and gyros added?
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
A Centralized Code Dump? colt527 Programming 29 01-01-2005 16:07
Interrupt timer, executing code asap? SeanCassidy Programming 10 07-03-2004 01:47
