Go to Post Remember: This is High School Competition. - rich2202 [more]
Unread 10-01-2005, 08:46
rcubes85 rcubes85 is offline
no team (TBD)
rcubes85 is on a distinguished road
Send a message via AIM to rcubes85
Best Drive system
Hay what up folks was wondering what you guys think would be the best drive system to use this year. I personally would chose threads because you will get a lot of grip "traction" on the carpet, and its pretty easy to control. What do you guys thing.
you can run from the past
you can change the present
but you can't outrun the future
becuase what you do in the presents depicts your future
Unread 10-01-2005, 10:13
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
Re: Best Drive system
In my experience, treads are more trouble than they are worth. You can get a niiiiice amount of traction using regular wheels.
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
Unread 12-01-2005, 17:27
Ryan Cumings's Avatar
Ryan Cumings Ryan Cumings is offline
Programmer and University Rejected
#0134 (Team Discovery)
Ryan Cumings is an unknown quantity at this point
Send a message via AIM to Ryan Cumings
We have used treads for the past four years, and from my opinion I can safely say that using treads this year will not give us a competitive advantage and we are going to use the pneumatic wheels. There are not obstacles or slopes climb or slippery surfaces to drive on.
Suddenly being rejected from college feels right during the build season. Now I am a mentor.
Unread 12-01-2005, 17:28
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Personally, i would support tread system or 6 wheel drive. but you can make EVERY single drive work if you do it right.
-Arefin.
Unread 12-01-2005, 17:41
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I'm not sure if you witnessed the horrendus failure of several robots last year due to pneumatic wheels (I probably should note that many others had great success), but if you do it, do it right. Either use only two pneumatic wheels, or keep the track width much wider than the wheelbase is long, or have 6 wheels sith the center ones lower. In a standard 4x4 configuration, a pneumatic wheeled robot may hop and jump all over the place. I'm not saying pneumatic wheels are bad, I'm just saying make sure you really want them, and all the inherent problems that may come with them.
Unread 12-01-2005, 17:53
You mean the problems that become apparent (such as turning) when you use tracks and your robot is longer than it is wide (IE the tracks are on the long side of the robot vs. the shorter side)? If so, we think we will be all set by using a 6 wheel drive and lowering the center wheel by half an inch or so (not a final number).
Unread 12-01-2005, 18:46
Lisa Perez's Avatar
Lisa Perez Lisa Perez is offline
FRC #0573 (Mech Warriors)
Lisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond repute
We like to keep things simple yet maneuverable, so we will be going with a tank-steer 4WD this year. Although four wheels may not have as much contact with the ground as treads, we feel that if we obtain wheels with a high friction coefficient, we can achieve almost as much traction, with less scrub.
We have worked with treads before, and they did not work out well for us. We tried to counter our issues with air rides, however, problems still came up.
At any rate, with the 4WD drive we should be able to have a decent turning radius, which will lead to greater maneuverability, which in turn will allow us to go around the goals and any of the other 5 robots with ease .
Event Coordinator - Center Line District Event
Volunteer Coordinator - Michigan State Championship
Lead Mentor - Team 573, Mech Warriors
Former Mentor - Team 830, Rat Pack and Team 3182, Athena's Warriors
Proud Alumna - Team 573, Mech Warriors and Team 1, Juggernauts
Unread 12-01-2005, 22:24
occra 23.
AKA: ryo
None #1481
um just to make sure, higher coefficient of friction=more scrub if non 2wd or omnied. and if you use tank steer, not as in treads but as inright power and left power. not car steer with one power and one steer, turning circles should be 0. as in turn about itsself. right forward, left backwards. so turning circle should be the same. turning rate is the word you probably wanted to use.
good luck! i personally like 4wd over any drivesystem. just an opinion. and we know you guys can make serious 4wd machines.
Unread 12-01-2005, 22:32
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Except if μ is not the same laterally and longitudinally; some of the nicer tread patterns allow for significant friction in the robot's customary direction of travel, but much less in the sideways direction.
Drive System treds/tracks krhs_programmer Kit & Additional Hardware 12 14-12-2004 16:56
What teams have desgined a 6 wheel drive system? Alex Cormier Technical Discussion 41 24-11-2004 12:26
Drive System Animation Project help is needed Brian Lesser Technical Discussion 4 12-10-2004 17:09
White Paper Discuss: SimSwerve Omnidirectional Drive System CD47-Bot Extra Discussion 11 14-06-2004 10:02
Quad- 1/2 track drive system Ben Mitchell Technical Discussion 24 30-01-2002 11:55
