Are we given sufficient sensors in the kit?
There's the accelerometer, and the Hall Effect Sensor (2).
Are these two sufficient for sensors on the robot, and if not, what else would be useful? Edit: My teammates seem to recall from the kick off video that the sensors provided in the kit would be sufficient, this is why i'm asking. Thanks for replies |
Re: Are we given sufficient sensors in the kit?
JMHO. |
Something that helps software out is knowing where certain parts of your robot are. Pots (variale resistors) connected to moving arms, steering mechanisms, etc. can report back to software and help modify robot reactions and assist in auto modes.
Microswitches can be used to limit travel or sense when a moving part has just about reached it's mechanical limit. Wheel encoders/shaft encoders can be used to tell how far you have driven. |
For the demonstration in the kick off I think the kit can be enough, depending on the programming and way of use. Obviously, you'll need more sensors for monitoring an arm, for example, or other specific function. |
There is no gyro in the kit?
I believe that the demonstration robot used a gyro and encoders. Neither were in the kit. If you want to use them, you have to buy them. |
#8
I know that a gyro can be used, actually I already used in an old project. I haven't read all about the sensor of this year's kit (which is not here yet), but I suspect that you can use for that function.
#9
#11
In the kick-off they said we have all the sensors we need inside the kit. they said we\d be getting a PID controller. does anybody know where that is? I can't seem to find it in the code.
How can the Acceleration meter be used as a gyro? |
#12
I'm not clear myself what a gyro sensor is, from what I've read and looked through, its some rotation sensor of some sort?
Anyone want to help clarify this for me? |
#14
The reason that a YRS give velocity rather than acceleration is that is uses the Coriolis effect in its design. Having said all this, you have enough info to Google away. If you have more questions after some investigation, fire away... |
#15
Now has anyone checked to see if the linear accelerometer that is included in the kit have a high enough resolution to be useful? The spec sheet didn't seem to convince me. |
| Coding CDs in the kit -- What'd you get? | elyscape | Programming | 1 | 08-01-2005 14:31 |
| need standard kit gearbox | Korbin | Kit & Additional Hardware | 0 | 15-11-2004 21:18 |
| Getting Fancy with Sensors | FadyS. | Programming | 30 | 10-03-2004 15:02 |
| Why not analog sensors?? | gnormhurst | Programming | 16 | 07-03-2004 16:14 |
| Q&A Discuss: How many Van door motor(s) come with the kit? | CD47-Bot | Extra Discussion | 1 | 08-01-2003 11:07 |
