Go to Post COMPETE like crazy for the 2 minutes you are on the field, COOPERATE like crazy all the rest of the time. When we play this way, we all win. - Chris Fultz [more]
Unread 11-01-2005, 00:12
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
pic: Sheet steel resting on CNC plasma cutter
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: pic: Sheet steel resting on CNC plasma cutter
1/4" plate? I believe the spec is .098 Why so thick?
Unread 11-01-2005, 00:30
Elgin Clock's Avatar
I believe I can answer this one correctly.. and Hopefully Jay may see this tomorrow morning and verify my answer.. but...
I think the ones we cut for this were to make the Center Goal Assembly or.. Tetra Goal mockup from PVC, and not buy a Tetra Goal with connectors and what not, but make our own version of them..
I think. And, since the specs for those are not given, and weight is not an issue, but geometry is, then material doesn't really matter as long as it is as close as possible to the "official" Tetra Goal as possible..
I think..
Unread 11-01-2005, 05:46
AKA: Jason Hartmann
I think..
Correct. We needed more clover connectors for the mock goals and someone suggested trying the new plasma cutter in doing them. 1/4 mild steel plate was what we happened to have on hand in the machine shop. The clovers that came in the kit we used to assemble a tetra with so those were used up.
Remember, this was also a learning experience with the new CNC plasma cutter. We're just practicing with the CNC programming and the settings on the machine so when the time comes to start fabricating actual robot parts we will know how to do it.
In case anyone's wondering the computer the plasma cutter is attached to uses AutoCad to layout the designs. If you do a design in another program you'll have to import it into AutoCad. The school we're based out of uses CadKey which we have no choice in.
