Go to Post Losing, like criticism, is the only thing that makes you improve. - MooreteP [more]
Unread 12-01-2005, 15:06
Charley's Avatar
Charley Charley is offline
Alumnae, Capt v2 for ever.
None #1350
Charley is on a distinguished road
Send a message via AIM to Charley
Transmission Set Screws
Our transmission set screws are too long, did they say there were supposed to be shorter ones in there?
Does any one else have this problem?
Charlotte.
Team 1350
Manchester 2003 Rookie All Stars
Unread 12-01-2005, 15:19
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Re: Transmission Set Screws
In the video they demonstrated taking the ones in the gears out and replacing them with shorter ones that were supposedly included with the gears. They mentioned that the ones already in the gears were too long and would bind in the completed gearbox. If you do not have those extra set screws or the extra ones are too long I would ask FIRST or see if they are listed on the KOP list to make sure you ask for those by today.
See you in DC!
Unread 12-01-2005, 15:20
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
See http://www.ifirobotics.com/kitbot.shtml
FIRST said you need to replace the included screw with a smaller one, or if you so choose, get rid of it all together.
2001-2004: Team 100
2006-Present: Team 254
Unread 12-01-2005, 15:41
jeremy562 jeremy562 is offline
Engineer
#0562 (SPARK 562)
jeremy562 is an unknown quantity at this point
Send a message via AIM to jeremy562
There are smaller set screws in the kit. However, they are in a separate bag, not with the transmission kit.
SPARK 562: Students Pursuing Applied Robotics Knowledge
2006 BAE Granite State Regional: Finalists with 319 and 176
2006 BAE Granite State Regional: Winners of Motorola Quality Award
2004 BAE Granite State Regional: 7th Seed
2004 Mayhem on the Merrimack Champions! Thanks, 61 and 1289!
Unread 14-01-2005, 13:52
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
We found that one of our tyranny's locked up and one made a clicking noise. Ground down all four set screws (one on each of the four motors) and problem went away
They run great now.
Wayne Doenges
CAD Mentor
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 14-01-2005, 14:25
President, VEX Robotics, Inc.
Wayne,
I did exactly what you did when I got the first production units in December. I then recommended that FIRST put the shorter screws in the kit. Your team should have 8 short set screws that came in a separate bag in your kit. Those do not have to be ground down.
-Paul
Unread 15-01-2005, 15:41
Gdeaver Gdeaver is offline
FRC #1640
Team 104 assembled our transmissions Friday night and had clearance problems with the short set screws. Filled them down. Also had problems with the spring clips. Had to remove them. We're debating if they're needed.
Unread 15-01-2005, 15:57
Gdeaver,
Are you sure you had the short set screws? The screws that come with the pinions are too long. You should have had short ones in a different bag. The short ones are only 1/8" long and are flush with the pinion hub. If you use the set screw, you do not need the retaining ring.
-Paul
Unread 15-01-2005, 16:22
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
The mentioned shorter set screws are in "Misc. bag II". At least that's where we found them today, along with more nylon washers.
Our nylon washers fit the motor output shaft perfectly, but we had to bore out the I.D. to get them to fit over the other shafts.
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 19-01-2005, 21:36
elknise's Avatar
elknise elknise is offline
AKA: Erik Knise
FRC #1318 (Issaquah Robotics)
elknise will become famous soon enoughelknise will become famous soon enough
We can't tell, but it looks like our spring clips are rubbing. Is it ok to leave them out? Also, our 1/8" long set screws were in Misc Bag II and they were a tad to long, they did stick out a little. I was wondering if filing them down would decrease the sound in our transmissions.
Also, regarding filing out the nylon washers. In the Misc Bag 2, there are four that have a slightly wider whole for the two shafts in each transmission, not the motor shafts. I hope this helps. When we set up our transmissions, we messed this up and put the four larger washers on the motors on accident and had to totally disassemble both of them and switch them out.
Elknise
Issaquah Robotics
Is a shifting transmission really necessary? Jay TenBrink Technical Discussion 78 02-08-2005 09:21
Slickest drive transmission yet... dlavery Technical Discussion 58 10-01-2005 19:33
If set screws suck . . . Madison Technical Discussion 17 22-12-2003 19:19
set screws CURTIS Inventor 0 03-12-2003 15:33
Motor coupling archiver 2001 19 23-06-2002 23:35
