Go to Post I had told my new team this joke: "They procrastinate so much, no wonder they're the Heroes of Tomorrow!", but I guess the joke doesn't have any truth in it anymore. They were really on their game this year! - JABot67 [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 14-01-2005, 08:26
Coachmac's Avatar
Coachmac Coachmac is offline
Team Coach
#1670 (The Loose Nuts)
Coachmac is an unknown quantity at this point
Pinion not machined correctly
So, were putting the drivetrain and gear boxes together last night and we hit a snag. on the second gear box, the pinion (FRC-2005-112-005) on the small shaft is milled wrong. The center is twisted and will not go on to the shaft completely. Has anybody else run into this? How did you remedy the situation? Did you just buy a new one? Should there be a replacement at no cost to us? thanx
"Life isn't about finding yourself... it's about creating yourself."
George Bernard Shaw
Unread 14-01-2005, 10:13
InnovationFirst's Avatar
InnovationFirst InnovationFirst is offline
Official FIRST Supplier
InnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond repute
Re: Pinion not machined correctly
Please refer to the thread at the IFIrobotics forum: http://www.ifirobotics.com/forum/viewtopic.php?t=174
Unread 14-01-2005, 10:28
President, VEX Robotics, Inc.
Innovation FIRST sent me an example of the bad part. A recommendation was made on the ifirobotics.com forum in this post:http://www.ifirobotics.com/forum/viewtopic.php?t=174
A pdf file with a picture showing a bad gear mated on the shaft is referenced in the above post link. I am also updating the transmission manual page 2-9 to show which direction to put the gear.
Referencing page 2-9, the FRC-2005-112-005 and -003 should be oriented as shown in the picture. The gear and the shaft are not symmetric. If you place the gear on from the same side as the bearing (not as shown), then you can use a brass or dead blow hammer to get the faulty gear on the shaft. This should cause no pre-mature wear on the gear and it should function normally. The gear does not have to be re-worked.
-Paul
rack and pinion. greencactus3 Pneumatics 17 04-11-2004 23:24
Converting the Bosch Metric Pinion into an English- Specification Pinion evolution Motors 3 28-08-2004 16:30
Removing Drill pinion Rickertsen2 Technical Discussion 14 18-02-2004 13:41
Drill Motor pinion Justin Stiltner Technical Discussion 2 21-01-2004 02:43
Chiaphua Motor Pinion Gear Joe P Inventor 0 27-02-2002 15:48
