Programming Problem: Extremely Frustrating
We were programming fine, everything was going well. Then we started getting an error. The program light on the robot controller would switch between red and green blinking very fast. Somehow, we don't know how, we were able to fix it. Then we got the same problem again, and now we are stuck. The two similarities between the two cases was that a person tried to download the new code into the robot while the program light was green and not yellow. I have searched many forums relating to this issue and this is what I have done so far to try and fix it:
1. We tried the hold down reset and program, release reset, release program, download, reset method 2. We have tried the hold down reset and program, release program, release reset, download, reset method 3. We have checked our batteries. 4. We have checked the connections 5. We have checked the wires We have also checked the radio signals. The joystick controller signal says transmit, but the robot controller signal says stand by. I think our problem is that the program won't run until the robot RC signal says receive. That is what i think the problem is. Can anyone tell us how to fix it? Also, can anyone suggest what else the problem might be and how we can fix it. Thanks. Team 612 |
Re: Programming Problem: Extremely Frustrating
We were finally able to download, however the only thing that seems to work is the FRC_Default code. When we build the new FRC code, without ANY changes it will not work correctly. Our code from last year will not work. The only thing working is the FRC_Default Code. Can anyone explain to us why this is happening?
once again thanks, ~Team 612 |
I'm not sure what could be wrong... but have you loaded the new firmware onto your controller? Available here. Maybe that can help *shrugs*.
Unplug all radios and tether.
Download the latest firmware. Download the default code. Plug in the OI via Tether. Reset Try downloading your code. |
The problem is not going away. I tried installing new compiler and master code. But still it does not respond to any other downloaded program except "FRC_default.hex"
Its very frustrating... chantilly team member. |
#7
Does the default code work?
If you can back out to very simple, "known good" conditions, and it still doesn't work, you may want to call IFI. I had trouble with the IF loader last year and they were very helpful. But first try to eliminate as many suspect things as possible, things that IFI cannot vouch for, which means your code and any extra connections. Back off to the default code. Unhook all unnecessary wires until the only wires you have are those required to test download and running. Get the new firmware and make sure you have the new compiler 2.40. Apparently last year's compiler does not support stuff in the new firmware. |
#8
We just did the firmware. Also the default works fine. We built the original code with no changes at all and sent it to the machine, and it did not work.
-downloaded firmware -default code works fine -compiled unedited code and did not work -we also had it working fine and were editing and getting it to work, until we put this line of code in: printf("potval: %d", Get_Analog_Value(rc_ana_01)); note: I know that is not the right method/variable, but we did the right one, i am just on a different computer with internet to type this and can't remember it so as i said until we put that printf in it was working fine, then when we took the printf out it didn't work thanks for the help and keep it coming |
#9
Last year we had the same problem (program light flashes red/green quickly). Our problem was we had a printf before we called Initialize_Serial_Comms().
It was a tough bug to track down, because every time we uploaded the program it worked until we reset the robot. Once we reset it started doing the red/green flashing. |
#11
But, it may seriously just a weird hardware error which will be fine after it gets a chance to cool down. |
#12
The code compiles fine without any error. But after downloading the code into the Robot controller, all the lights on it start blinking rapidly. Even if compile the default code(without any changes in it) and then download it, it has the same problem. But it responds perfectly when we download the "FRC_default.hex" into it, instead of "FRCcode.hex" We tried shutting it off and turning on after few hours, it doesnt work. We are having this problem for the past whole week. Any kind of help is appreciated.
Chantilly team member. |
#13
A couple of possible reasons this could be happening are:
#14
Thanks, Chantilly team member. |
#15
| Programming - Getting Started | Mark McLeod | Programming | 80 | 16-04-2008 23:37 |
| Banner Sensor Programming Problem | 2Crisis | Programming | 4 | 24-02-2004 13:40 |
| C programming problem... | wasabi824 | Programming | 5 | 08-02-2004 01:04 |
| multi-bank programming problem | GregC | Programming | 3 | 14-02-2003 16:13 |
| programming problem | gthakore | Programming | 16 | 20-04-2002 12:21 |
