Go to Post You guys can send [Wisconsin] some warm Florida weather, its getting cold up here again. - Ricky Q. [more]
Unread 15-01-2005, 14:11
781Co-Cap 781Co-Cap is offline
781Co-Cap is an unknown quantity at this point
Pitch of Jideco Motor
Does anyone know the pitch of the gear on the jideco window motor?
Unread 23-01-2005, 15:20
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Pitch of Jideco Motor
Has anyone found out the specs of this gear, or how to mate with it? Help would be greatly apprecieated. Specs are best, but other ideas for mating are good too.
Unread 23-01-2005, 17:48
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Best I can do
Unread 04-02-2005, 20:37
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
It looks like the gear on the Jideco is an 8 tooth, mod 2, 30 deg pressure angle. At least that is as close as my poor old eyes could measure. I've attached the Inventor part I made of it.
No guarantees about accuracy, your mileage may vary, do not eat Jideco Gear, etc.
When you open the Inventor file the screen will be blank. Grab the End of File marker (red circle with x in it) in the browser and drag it down to the bottom of the browser. The part should then be visible. Save it. (Moving the marker is a trick which reduces the file size dramatically).
Pete Kieselbach
Multiple Motors phrontist Motors 12 21-06-2004 23:05
Mounting the drill motor Veselin Kolev Motors 11 26-04-2004 14:27
BOSCH motor pinion pitch Matt Reiland Technical Discussion 2 10-01-2003 09:26
Thermal Protection archiver 2000 1 23-06-2002 23:27
Jideco Motor Spec's (wanted) Larry Barello Motors 1 15-01-2002 21:58
