Go to Post I like anything that is designed to bounce for up to 10 minutes. Expecially if it lands right side up :) - GregT [more]
Unread 15-01-2005, 17:05
Isabel Cole's Avatar
Isabel Cole Isabel Cole is offline
AKA: mama cole
FRC #0974
Isabel Cole is on a distinguished road
Camera "Grab Frame" Problems
Hey guys! I've been working with my team's camera and the first time i did it, everything worked and the camera was grabbing frames but everything was really fuzzy. But now that i go back to it, the "grab frame" option doesn't even seem to be working. It's not loading a picture and the system freezes on my computer. Did i miss a step the second time that is screwing up my camera? You tell me.
-Isabel
Team 0974
Unread 15-01-2005, 17:27
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Camera "Grab Frame" Problems
As for fuzziness, make sure the camera is in focus. You can adjust the focus by turning the lens ring on the camera (or so I understand).
Unread 15-01-2005, 17:36
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Did you have it verify the camera (as stated in the "getting_started.zip" file, so that it shows the camera type in the text box up top, and "FRC" in the bottom-right corner?
Dan
Unread 15-01-2005, 17:43
Damian Manda's Avatar
Damian Manda Damian Manda is offline
The Damian
Damian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud of
Send a message via AIM to Damian Manda
The application seems to crash a lot on our computer as well. Usually we just have to end the program and restart it. If this doesnt work, cycle power to the camera and robot, and make sure the backup battery is plugged in and charged (this seems to matter for some reason). Also, If you are using the camera on the computer it seems as though it cannot be plugged into the RC TTL port as well, so make sure this is unplugged.
FRC Volunteer, FLL regional planning committee member for Colorado
Former Programmer, Web Designer, Communications Director of Alpine Robotics Team 159.
Add your team to the FIRST Teams Google Map
Unread 15-01-2005, 18:23
AKA: mama cole
FRC #0974
we did try to focus it by turning the ring on the lens but it didn't do very much. the focus was very minimal.
as for what's wrong with the program, we're getting an error message with
the config.txt file whenever we upload the system. any thoughts on that? because i don't remember it ever coming up before (obvioulsy becasue it worked the last time, other than it being out of focus) but we don't know what's wrong with the file therefore we dont' know how to fix it.
thanks guys!
isabel
team 0974
Unread 15-01-2005, 20:55
AKA: mama cole
FRC #0974
well we figured it out. it was really simple too which sorta pissed me off: you need to have the program running before you run power through the camera and the robot controller. also, we were using compressed files; that's what the error message was for.
thank god for genius mentors!
thanks for your input i appreciate it!
Isabel
Team 0974
Unread 15-01-2005, 21:38
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
I haven't found this to be true. In fact, I always have the camera powered before I start the GUI. I guess it's just peculiar to your situation.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 15-01-2005, 21:53
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
I have always powered up the camera first, but whatever works for you.....
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
Camera Problems pickle Programming 21 20-01-2005 20:43
Camera Problem n_0163 Electrical 3 14-01-2005 21:10
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
