Camera fails to output anything on serial lines
I've wired up the camera - I'm using the 2002 mini RC for power, and I then hooked up the camera and serial lines. Upon powering up, all three status LEDs turn on and the servo twitches. Very quickly, the green status LED (the one to the left) turns off, leaving the green power LED and the red status LED on. Nothing appears on my terminal. I tried typing 'gv' as was suggested by the directions to no avail. The GUI fails on any command, often crashing in the process. I'm providing about 7V of power, more than the minimum 6. I have no clue where to go from here - how else can I go about debugging the camera? Thanks,
Steven |
Re: Camera fails to output anything on serial lines
Lots of people (myself included) have had trouble running the GUI on slower computers, as has been noted in other threads. I tried a number of the school's computers (1.0GHz Celeron, I think) with no success. I brought in my own 1.8GHz computer for our programming team, and it worked fine. Make sure that your serial port is configured properly first. If it is, try setting the camera up on a faster computer, and see if it works there.
I saw those, and figured that it's not the problem because nothing at all appears on the serial port - the documentation says that the firmware should spit out a version string (and I'm fairly positive I have the settings right, although minicom isn't my favorite interface) and nothing appears (and even if it was the wrong speed or something, at least some sort of garbage would appear)
On the school computers I was using, I couldn't even get the version string out of the camera. Try it on a faster computer; then you can see if that's the problem, or if your hardware is malfunctioning.
That's very strange - why would a 366MHz computer be unable to read ten bytes off of a serial port? They existed long before such fast computers did...
I don't think I have a faster computer readily available. I'll check out the clockspeed tomorrow and look around, however... |
I haven't changed the jumpers from the default settings (all open). Should any be closed for normal operation?
#7
If anyone has gotten these cameras to work, please post computer specs and settings, along with any modification done to the camera. |
#10
I just got it to work - apparently 1.6GHz is not enough but 1.8 is. This is very strange, and somewhat disappointing - I can see no reason why the system requirements would be that high and there is no way we'll be able to bring such a fast computer to our competitions, seriously affecting how well we'll be able to debug problems...
| Scripting Setup and the Camera + Serial Port Drivers | CJO | Programming | 22 | 11-01-2006 17:42 |
| Kevin Watson's Kick-off Demo Code! | Mr. Lim | Programming | 27 | 22-01-2005 03:38 |
| CMUCam2 Camera Code - Are important parts commented out? | Mr. Lim | Programming | 4 | 14-01-2005 12:11 |
| New Serial Port Driver | Kevin Watson | Programming | 16 | 09-01-2005 01:56 |
