Go to Post A true team can only be formed by people who care about each other and that have a common goal... - keehun [more]
Unread 16-01-2005, 22:17
KVermilion's Avatar
KVermilion KVermilion is offline
... clearly ...
#0649
KVermilion is infamous around these parts
Tri-axis Analog Joystick
I've been looking for most of the day on a way to use a three axis joystick... and no dice...
This could be done in one of three ways:
  1. Convert the signal of a digital tri-axis joystick to analog.
  2. Modify a digital tri-axis joystick to by pass digital encoding (if it uses pots).
  3. Find an analog tri-axis joystick.
Number one would be pretty hard, because it would require sniffing of the packets using a program, and then it would require design of a custom circuit (fpga, multiple DAC chips, etc). This is obvously not in the scope of the remaining 5 weeks of build time, but this could possibly be done during the break between shipping and regonals (Is this allowed? It is OI work...)
Number two would require a tri-axis joystick that uses 3 100k pots and some minor wiring.... Yeah, but how do we find a candidate?
Number three would require pretty much no "work" but allot of research... The MS Sidewinder 3D Pro (a very, very old dual mode triaxis stick) Does anyone have this stick? Does the third axis work in analog mode?
Unread 16-01-2005, 22:24
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: Tri-axis Analog Joystick
It looks like there are a couple of those joysticks around: http://froogle.google.com/froogle?q=...ff&sa=N&tab=wf
If you get it working, let us know.
Team 1257
Unread 18-01-2005, 23:51
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
you know, you could just cut the main 'stick' part off of the base, and glue a pot inbetween so you can turn it. (are we allowed to modify the joysticks?)
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Unread 19-01-2005, 00:01
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
I have an older logitech equivalent of the sidewinder 3D, it is an excellent stick, and all three axis + the throttle are analog.
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 19-01-2005, 00:18
Andy A. Andy A. is offline
Getting old
FRC #0095
Yes, you are allowed to modify joysticks. In fact, there are not many rules regarding the OI side of things. There are rules, and you can consult the manual for them, but as long as its not going to catch on fire or hurt anyone, and isn't computer controlled, it's probably legal.
If it works or not... well, there have been lots of really brilliant control ideas that just plain never worked in the end. It's hard to beat a good old fashioned CH flight-stick from a few years ago.
Your idea of hacking up a joystick could work from a legal standpoint and I think a practical standpoint. It might require a bit more work then you might first think though, especially if you wanted a spring return or any sort of damping in it.
My suggestion would be to find a digital 3 axis stick, and simply bypass the internal circuitry. You'll have to wire each pot to one of the 4 analog inputs on any given port, and do the rest in programming. It's a little bit of surgery, and you'll need to make your own connector, but it's nothing terribly complex. I imagine it's already been done.
Interestingly, a lot of the CH joysticks are already 3 axis, with the third being the throttle wheel.
Just make sure that the pots in the joystick you are using are 100k!
-Andy A.
Unread 19-01-2005, 00:24
KVermilion's Avatar
... clearly ...
#0649
RIGHT.
How exactly are you thinking this will happen? if the pots are disconnected from the pcb you have a single (twist) axis joystick... I'll need to open up one of the righthaned beige 04+ sticks.
Also, I'd need a 100k ohm spring return pot. Havent found (m)any, also, the driver, might break the stops of such a pot, so I guess a mechanical stop outside of the pot would be very good....
Does this stick work with the OI? basicly, if the pinout is that of a CH FligthStick, one of the extra axes used for uh... throttle? and somthing else... will be the z (twist) axis...
Also, what model is this? Do you still want it?
AFAIK, all modern and most digital sticks are OPTICAL!
Problems hooking up a joystick to edubot Salik Syed Programming 2 24-03-2004 23:56
Inverting Y axis on joystick FormatteD_C Programming 7 24-02-2004 16:56
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
