Pneumatic's Rules confusion
i know there is another thread but it doesnt get any traffic
im very lost with these rulings about the pneumatics we are going to use the free cyclinders from bimba however we got a rotary from parker Also we were lookin into pneumatic devices (ex pneumatice gripper (pre made) Are they allowed (both the rotary from parker and/or the pneumatic devices) Another question: is it possible to use a bimba non rotating linear pneumatic |
Re: Pneumatic's Rules confusion
The rotary from Parker is allowed as long as it meets the same specs as Bimbas. You are not allowed to use the gripper if it comes with cylinders that are not on the allow list. You MUST use only the cylinders from the allow list. For your last question, if it is not on the list you cannot use.
Hope this helps. |
Thanks
However im still confused with the rules why do they say any off the shelf pnuematic devices (i would think this just means no home made pneumatics for safety) and then go on to say only bimba and parker linear and rotary from the order list If you were to buy a gripper already made that isn't a linear or rotar but more like a custom pnuematic couldnt you use any make Why wouldnt you be able to use non rotating When you order a normal cyclinder from bimba they always have the option but once you go to the free FIRST section then there is no option |
the rule about any off the shelf componets deals only with fittings, solonoids, tubing...basicly anything except the cylinders and the storage tanks....
you are limited to 2 storage tanks just like the 1 from the kit and any cylinder that is the same specs at on the order form in the back of the manual. |
FIRST has an agreement with Parker and Bimba. They also try to level the field with other teams. The cost of the cylinders could prevent some teams from equal field. I wanted to use the non rotary as well but they are unfortunately not on the list.
im really confused now
i have a contact at another team and he says that in the past they can use other pnuematics as long as the team pays out of their pocket Also i heard that one year they allowed a team to use all SMC pneumatics |
#7
There are no 1/2" bore cylinders on the order sheet only 3/4", 1-1/2" and 2" bore.So you can not use 1/2" bore cylinders of any stroke?
Thanks |
#8
It does seem a little more confusing than last year.. the best I can understand it is that you can use as many cylinders, rotary actuators, etc as you want, as long as they are listed on the custom order sheet.. but the thing that is throwing me off is the flow chart.. it states that you can use any pneumatic devices off of previous year's bots.. so if I have a 1/2in bore (they are not on the list this year) on last year's bot, can i take it off and use it this year??
j |
#9
Well, a few years ago we used an off-the-shelf NON-CONTROLLED pneumatic device... a suction cup for carrying glass, we then in turn used a pneumatic from bimba to actuate the hand-pressed pneumatic on the glass. Since that was unmodified off-the-shelf part, it was ok.
Dont know if that relates to your problem though. |
#10
With regard to the allowed pneumatics for this year, read <R90> and <R91> very carefully. Quote:
-dave |
#11
Dave maybe you can find the answer to this question. I asked on the Q&A if you could use 6ft coiled connector hoses that are off the shelf. Now according to the rules they are connectors and off the shelf. They are not storage devices. Last year for some reason they were disallowed. They are the same diameter as the current hose that we receive in the KOP. The safety issue that we are concerned about is better because coiled hose does not flop around on the robot or swing in open air. When I asked the question all that was answered was check the flowchart. Why does FIRST not give us a yes or no answer. There is nothing worse than building and getting to a regional to find out that something is disallowed.
Thanks in advance for any clarification. |
#12
With that in mind, as I read <R90> and note where it says you can use an unlimited number of "connecting fittings" I put the simplist interpretation on that phrase that I can. A fitting is a simple, monolithic piece used to connect two other parts with dissimilar physical interfaces, such as the bag of brass fittings that come with the kit. A connector hose is not a single fitting, it is an assembly of two (or more) fittings and a hose. So let's then go through the flow chart for each of the individual parts of the assembly. Each of the individual end fittings would safely fall through the flow chart, and would seem to be OK to use. But the hose is another matter. It falls through these logic blocks: it is a pneumatic component; it is not an air cylinder; it is not a purchased fitting, valve or purchased air cylinder; and it is not a piston or valve from last years robot. Therefore, the hose itself would be illegal. Double checking with <R90> and <R91>, we see that "tubing" is not explicitly listed as an "unlimited" item. So, in the case of our team (and as mentioned above, we take a very conservative approach to the pneumatics rules), we would say that the connector hose failed the flow chart test and would not use it. This is my opinion only, which is being provided at no cost and is therefore worth what you have paid for it. Your mileage and interpretation may vary. ![]() -dave |
#13
Dave, thanks for your reply. Even though you say I get what I pay for I believe it to be of more value. When you see me next be sure to collect your $0.02.
I guess I don't understand the logic all together. As sold off the shelf the "hose" is sold as a connector hose which I understand from some sides may be seen as stretching (no pun intended) the term. For an safety point I am totally lost as why FIRST wouldn't want someone to use this off the shelf product. Maybe I will ask the question again to get a yes or no answer rather than "let's see what happens" rule. Thanks again for your insight. |
#14
I'm not trying to get into a debate on grammar, just clarification on the second half of <R90>:
(A): "...they must be: - identical to those listed on the Pneumatic Components Order form - obtained from a Bimba or Parker Hannifan distributor Or (B): "...they must be identical to those: - listed on the Pneumatic Components Order form - obtained from a Bimba or Parker Hannifan distributor At least if i read this correctly... (A) means that cylinders MUST be Bimba/Parker BRAND (only in sizes listed on the order form) while (B) means the cylinders could be other brands, provided they are otherwise (size/type/style) identical to Bimba/Parker (only in sizes listed on the order form). I only ask because if we could use other brands (rated the same and visually identical to Bimba ones) that are carried by places like McMaster Carr or MSC teams could order, receive, and implement them MUCH faster. My experience with FIRST says that (A) is correct, but my common sense says that (B) should be correct. -Bill (I know already that it is usually unwise to try to apply common sense to FRC rules ) |
#15
For example, can we use a modified off the shelf gripper? Keep in mind the pneumatic portion is in its original unmodified condition and is a COTS item.
Bah, I'm so confused Thanks |
| You write the forum rules | Ken Leung | CD Forum Support | 8 | 17-01-2005 11:18 |
| Uniform rules and enforcers? | Ben Mitchell | General Forum | 31 | 12-01-2005 20:55 |
| Dilemma - Letter of the rules v. spirit of the rules | Natchez | General Forum | 27 | 03-04-2003 15:37 |
| Time for new rules! | archiver | 2001 | 11 | 24-06-2002 02:01 |
| Robot electrical systems rules | Morgan Jones | Rules/Strategy | 5 | 06-01-2002 00:50 |
