Go to Post Hundreds of teams. Thousands of students. Countless memories. Infinite fun. You'll love it, I promise you that. - smurfgirl [more]
Unread 17-01-2005, 13:55
cherubrock5 cherubrock5 is offline
cherubrock5 is an unknown quantity at this point
Exclamation Operator Shelf Dimensions
Hello,
What are the dimensions for the operator shelf (i.e. the place you set your control board for the driver) I know in one post it said the aluminum shelf was 12" deep and 12' long. Does this mean each team has roughly 4' length to work with?
Thank you,
Jesse K.
Team 1317
Unread 31-01-2005, 09:27
scharfman90's Avatar
scharfman90 scharfman90 is offline
AKA: Zach Scharfstein
None #1676 (Pioneers)
Team Role: Electrical
scharfman90 is an unknown quantity at this point
Re: Operator Shelf Dimensions
The Operator Interface Console designed by your team must fit on the 69” wide by 12” deep shelf in the Alliance Station and the radio modem connected to the Operator Interface must be able to reach the mounting bracket on the operator stations. Be sure to leave at least 48” of slack in the 9-pin cable.
Unread 31-01-2005, 11:36
The shelf is also 34" off the floor.
Be aware that if you plan on pushing the limit the 69" wide includes the emergency stop box.
Name:	Driver shelf.jpg
Bosch Drill Motor Clutch Spring Dimensions?? aaronbr28040 Motors 3 18-02-2004 19:52
Beacon and 10 Point ball PVC frame dimensions MrB General Forum 2 28-01-2004 08:35
Can LEXAN exceed robot dimensions? RAWdealer59 Rules/Strategy 13 05-03-2003 22:05
Robot dimensions & weight restrictions revealed? Mike Soukup Rules/Strategy 4 24-10-2001 20:51
Field and shelf missing dimensions kmcclary Off-Season Events 3 12-10-2001 18:21
