Go to Post Dave Lavery, Lou Rosanio and Karthik are all Woodie Flowers winners this year. So mentors it seems like if ya want the WFA it might be a good idea to put on a kilt :) - Kyle [more]
Unread 17-01-2005, 17:35
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
Question about drill transmission specs
Hi, I was wondering what the inside diameter of the gear that imnderfaces with the pins that holds the planetary gears and the dimensions of the keyway. Thanks
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
Unread 17-01-2005, 18:33
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Question about drill transmission specs
I have no idea what you are talking about!
which drill, which planets, which keyway... ..help me out here?
Joe J.
Team #88, TJ2
Unread 17-01-2005, 23:55
I was asking for info on the bosch drill transmissions provided in the 2004 kop. In the transmission, the pinion gear interacts with 5 14t planetary gears. A gear above it, that has pins that these planetary gears spin on has a hole in it that is keyed. I wanted to know the diameter of this hole, since it is a circular keyway, what the specs are on the keyway, if that is possible. Again, thanks for your help.
Unread 17-01-2005, 23:58
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I'm betting some nice calipers would do the trick. Do you have any? If so, just measure it.
Unread 18-01-2005, 00:14
it's not so much the diameter. The problem is that I also need to know the specs on that key way and haven't a clue about how to find that out because it's a circular keyway (I did use calpers and my reading was 6 mm for the diameter, but it didn't seem real solid on 6 so I was questioning it)
[OCCRA]: drill transmission greencactus3 OCCRA 4 14-10-2004 22:33
[OCCRA]: [OCCRA] drill transmission greencactus3 OCCRA Q&A 1 11-10-2004 19:31
Need info on gears inside drill transmission. sanddrag Motors 7 14-04-2004 11:01
CAD of Bosch drill motor transmission? Crazy Inventor 7 21-01-2004 12:03
BOSCH Drill Transmission Assembly archiver 2001 2 23-06-2002 22:08
