Go to Post There's more to the game then winning. - Gabriel [more]
Unread 17-01-2005, 18:59
Waste
Posts: n/a
Smile number of joysticks
hey all. im the team captain from newtown h.s, and this is our first year doing first. im really excited about the competition and naturally as any rookie i got tons of questions. my first major problem is the amount of joysticks being used. i tried searching the forums and ive gone through the rule book and unless im blind and missed the answer, it just wasnt there. so, if anyone could help out, how many joysticks are being used to control the robot? and are we allowed to change the amount of joysticks we use? thx everyone
Unread 17-01-2005, 19:00
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: number of joysticks
As many or as few joysticks as you'd like. There are no rules regarding them. You could buy a completely different joystick if you wanted to.
2001-2004: Team 100
2006-Present: Team 254
Unread 17-01-2005, 19:12
Waste
Posts: n/a
ahh thx a lot
Unread 17-01-2005, 21:09
misterfoo misterfoo is offline
Controls Mentor
AKA: Ken Leigh
#0811 (Cardinals)
misterfoo is on a distinguished road
Not that you asked this, but depending on the design our drivers have always found it handy to have several panic buttons on the control panel besides the joysticks and joystick buttons.
The "panic buttons" cause the robot to reset to some predetermined config. For example if you have a lift arm this year, one button could reset the arm angles to the grab tetra position (low) for instance. We found this to be helpful to have a big red button on the panel instead of remembering that button 3 on the joystick will do the same thing. In the panic of the competition it is good to have a few simple control points.
I will also second the other answer on changing joysticks and number of joysticks.
Unread 17-01-2005, 21:13
Stephen P's Avatar
Stephen P Stephen P is offline
Stephen P has a spectacular aura aboutStephen P has a spectacular aura about
Does FIRST say anything regarding the restriction of an Xbox controller? Many team members have experience with those things
You know you are an electrical engineer when you can determine voltage relative to pain with a 5% error.
Unread 17-01-2005, 21:19
Bremma's Avatar
Bremma Bremma is offline
That crazy girl
AKA: Heather Selbe
#0404 (Distant Rage)
Team Role: Electrical
Bremma is on a distinguished road
Send a message via AIM to Bremma Send a message via MSN to Bremma Send a message via Yahoo to Bremma
I'm pretty sure I read on the Q& A forum that it is legal, but if it doesn't work, FIRST won't help you.
Yay! New team name! We are now Distant Rage!
Robotics team #404 - Team Not Found
Unread 17-01-2005, 21:34
Anchi Anchi is offline
nekura
#1288
Anchi can only hope to improve
Send a message via AIM to Anchi Send a message via MSN to Anchi Send a message via Yahoo to Anchi
it runs off a cat5e cable, wouldnt you need to make a lil converter box?
"If knowlage is power, dose that make me a weapon of mass destruction?"
"Everyone is entitled to their own worthless opinion, only mine is important."
Unread 17-01-2005, 21:41
663.keith 663.keith is offline
FRC #1493 (Falcons)
663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all
Send a message via AIM to 663.keith
you may want to check out this post about converting an xbox contorler. Its pretty much out of the question, unless you completely gut the entire thing. (which our team may actually do this year )
http://www.chiefdelphi.com/forums/sh...ad.php?t=31057
http://www.wcsrobotics.com
team 663
team 1493
Unread 17-01-2005, 21:59
mgreenley
Posts: n/a
On a quick sidebar, consider a PS2 controller unless you've really got your heart set on an Xbox controller. We found that to convert it all you need to do is cut the plug off and solder the pins into the corect config. for the OI plugs. Word of advice though, having driven all four of our robots, I prefer a joystick to a gamepad. (That the KoP joysticks are only for right-handed people and I am..erm..was left handed is a completly different story).
Unread 17-01-2005, 22:15
fred's Avatar
fred fred is offline
More Grizzle
None #0341 (Daisy)
fred is on a distinguished road
definitely agreed, we could have done the ps2 controller last year, but unless you need about 8 buttons, there really isn't that much of a point, i still prefer the old black joysticks over anything else.
"The distance between genius and insanity is measured only by success."
-Anonymous
Unread 20-01-2005, 00:37
Pingponger17's Avatar
Pingponger17 Pingponger17 is offline
Pingponger17 is an unknown quantity at this point
I am on a rookie team this year and we have had some problems with our joysticks that came in our kit. We are having problems because the joystick is very loose and so it doesn't come to a complete neutral position. Also the calibrators on the sides move when you move the joystick. Any suggestions would be very much appreciated. Thanks a bunch! Would you suggest using the ones that came in the kit or get new different ones?
Unread 20-01-2005, 00:53
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Yeah first used to give out joysticks that were better. They switched last year to the ones now in the kit. They don't center very well and are for right handed people only. You can always go out and buy any analog joystick for a computer and it will work. you just have to figure out how it outputs and get the pins correct. (i'm pretty sure its standard on all joysticks though.) The problem is that most joysticks now are USB which won't work.
As for how many joysticks, most teams use two joysticks in a tankdrive set up. One joystick controls the forward and backward motion of the left side of the bot and the other joystick controlsthe forward and backward motion of the right side of the bot. You can do it with just one joystick though. Whatever is easiest for your drivers i guess.
Team Website
Unread 20-01-2005, 00:54
Xufer's Avatar
Xufer Xufer is offline
8 Seasons and as stable as ever
AKA: Working, 2/4 degrees complete still schooling...
FRC #1740 (The Cyber Colonels)
Xufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to behold
Send a message via AIM to Xufer Send a message via MSN to Xufer Send a message via Yahoo to Xufer
Well the real problem is that those white joysticks are HORRIBLE , there were alot of people last year who put in tighter spring and all in an attempt to make them better, but it doesnt help to much. Your best bet is to buy new ones in the past we were given joysticks from CH PRODUCTS the problem is the one they used to give us is no longer made. The newer version of it just has more buttons including a directional hat. Heres a link:
http://www.chproducts.com/retail/j_fighter_pc.html
the good thing is theyre only $20 a piece
But again you can use any joystick you like aslong as you know what the buttons map out to.
If saftey is first and i put FIRST ahead of everything, then i must be the safest guy in the world.
Team 521 Alumni -- Team 1740 Mentor-- Go Go 1740!
Sometimes I think I've been doing this too long and other times I think I haven't done this enough... but all the times I'm sure I'm crazy
Photonics, It's Your Future
Unread 20-01-2005, 08:32
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
We've always used 3 joysticks, two for drive, one for peripherals (Though we usually set it up so you can toggle between tank drive and single-stick drive). One slight problem is that all joysticks are righty. however, especially since we need a left handed one all the time (not just for our left handed drivers) since we use tank drive. We got around that by using an old FIRST joystick though.
The joysticks FIRST give you are not too bad, just make sure you trim them first and program a nice hole in the center where no movement takes place. If you have trouble with knocking the trim off while its being unused - hot glue them in place.
Now you guys are talking about XBox and PlayStation 2 controllers, etc. and you say you need to just change the plug. But Anchi is right, you need to convert the signal from digital to analog, not just change the plug. (You could however use a Nintendo, Super Nintendo or Sega Genesis controller by just changing the plug I believe.)
To throw my opinion in, I think it is better to use joysticks, its easier for most people to get used to while controllers it would only be good for people who like that controller. Like if you're thinking of using an XBox controller, would you use the S-Controller or the "Original" Controller? Personally I hate PlayStation 2 controllers so if you're using that, how am I supposed to drive? Joysticks are the most generic and user friendly when you take everyone's opinion into account, I think.
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 22-01-2005, 17:13
pakrat pakrat is offline
Rich Ross
no team (The Rat Pack)
pakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nice
Send a message via AIM to pakrat
I have a question:
Are these ones Serial? Cuz they look really good.
Thanks in advance
Sophisticated Joysticks WebWader125 Control System 3 03-12-2004 15:33
need joysticks! Tom Bottiglieri General Forum 14 24-02-2004 09:36
AVB joysticks..and other analogue joysticks tml240 Kit & Additional Hardware 6 07-02-2004 12:45
number of joysticks doy Rules/Strategy 5 01-02-2004 00:05
WASH scouting fields Mike Soukup Scouting 0 04-02-2002 02:39
