Four wheel drive question
Hi all,
For those of you that are creating robots with four wheel drive, how are you accomplishing this? The included gear box only supports two wheel drive and in order to get it to work four wheel drive you need two of part # FRC-2005-112-009. Innovation First claims that they, "do not sell the transmission gears or sprockets individually. The gear you are looking for is included in the transmission kit. We only sell transmission kits in complete sets." A complete set would be ridiculously expensive. My question therefore is how do you go around this technicallity to support four wheel drive, OR how did you order the two parts for four wheel drive without buying the whole set, OR does anyone have any extra of these parts? If anyone could help out this rookie team, we would greatly appreciate it. Thank you all, Jason, Team Leader 1656 |
Re: Four wheel drive question
one way to accomplish this would be to drive one set of wheels directly from the gearbox, and drive the other set with a seperate connector chain which is itself driven by those wheels already powered..
this would require adding another sprocket onto each wheel then adding the chain. you may also need to add a tensioner.....as it is a fairly long span for unsupported chain. also, look through the gallery. teams have been building four wheel drive robots since the start, and none of them have had a ready made two motor gearbox to start with. so you should be several steps ahead! ![]() |
We accomplished it by purchasing the ROBOT-SPROCKETS-2005 kit that is $79.95 at http://www.ifirobotics.com/kitbot.shtml
There are a couple of other threads that already discuss this. |
If you want to be very simple, you could order a double chain sprocket from Mcmaster. We also converted our wheels to use 5/8 shaft with a similar sprocket and a keyway. Here is what I found. http://www.mcmaster.com/ Search for Double-Strand (page 932) Steel Double-Strand Plain-Bore Sprockets for ANSI #35-2 to #60-2 Roller Chain |
We are just ordering more parts, because we are doing 4-wheel drive too.
GOOD LUCK! |
The sprockets that came in the kit are custom bored to fit on the kit-tranny shaft. You can't purchase stock sprockets and expect them to fit out of the box. They need to be bored out or at least pressed onto the shaft. This is the 4th time I've had to remind people of this in as many threads, such as this one. |
#7
why cant you make the robot 4 wheel drive with just ordering two more sprockets? add those to the ends of the drive shaft, drop another chain, presto! four wheel drive
#8
Refer to attached.
Here are 3 configurations of chain/wheels I sketched up in Paint that may be useful. Two are 4WD, using different sprocket/chain combos. One is 6WD. Just some food for thought. John Edit: Please note, these are just some ideas, there are TONS of ways to reconfigure a drivetrain, and the KOP chassis can be used for quite a few. Every team must decide what seems best. /Edit |
#9
Innovation First DOES sell sprockets individually, but not gears. Please refer to this page: http://www.ifirobotics.com/kitbot.shtml Note: you do not need any additional GEARS to make a 4WD system, only sprockets. You can buy 1 sprocket kit "ROBOT-SPROCKETS-2005" and along with the 2 extra wheels and wheel hubs included in the kit be 4-wheelin' before you know it. The gearbox is easily convertable to a 4WD configuration. In fact, it was originally designed with 4WD in mind. If you simply buy the extra sprockets, you will be up and ready to go in no time. If you have more problems, do not hesitate to ask, John |
#10
With the "ROBOT-SPROCKETS-2005" Kit ($80 + shipping) you can construct the 4WD configuration I show on the right in my above post. Isn't that awesome? Less than $100 for a fully working 4-motor, 4WD base. It's a brave new world. JV |
#12
I saw this FAQ on the IFIrobotics.com Site...
So, we also need the sold out hubs? Does this mean we also need an additional chain OTHER than the one included. Also, the sprockets listed below - those are IN ADDITION to the ones already in the kit (all four of them?), correct? Sorry if this is a stupid question... Thanks, Jason "What do we need and how do we make a four wheel drive system out of what we have in the kit? Please check section 3 in the "2005 FIRST Robotics Competition Kit Transmission Manual -RevA" document located at http://www.ifirobotics.com/kitbot.shtml. You do not need the custom PVC spacer used in the 2 wheel drive configuration and you need to use the 40mm key provided in the kit instead of the 20mm key. You also need additional parts to make the 4 wheel drive configuration. The additional parts you need are: 1. 21 tooth sprocket - Quantity 2. Available from ifirobotics.com 2. 28 tooth sprocket - Quantity 2. Available from ifirobotics.com 3. Skyway wheel hubs - Quantity 2 sets. 4. 10' of chain. Available from ifirobotics.com" Last edited by haverfordfords : 20-01-2005 at 19:37. |
#14
Kit Bot Parts
I just found out yesterday that IFI now sells individual sprockets of both kinds for 19.99$ |
#15
| Four Wheel, all steering, non-omniwheel, ONE power/motor source drive | FizMan | Technical Discussion | 31 | 27-04-2004 12:12 |
| Quatro 4 wheel drive | ufa_mike | Control System | 2 | 15-04-2004 02:30 |
| 2-wheel versus 4-wheel drive | Ben Mitchell | Technical Discussion | 23 | 07-11-2003 00:50 |
| XP Hard Drive Space Question | Raven_Writer | Chit-Chat | 13 | 07-08-2003 16:38 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
