Go to Post Secure your battery well, or it will fly like a fish. - Nate Laverdure [more]
Unread 20-01-2005, 00:49
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Analog Input Trouble
My co-programmer and I are having some trouble with the RC. We've tried both a potentiometer and a gyro connected to the first analog input. I tried to get the raw value using:
printf("Raw value:  %d\n", Get_Analog_Value(rc_ana_in01));
but it just prints -1. Any suggestions ?
Using newest compiler/IDE, firmware's updated and we're using newest default code.
Matt Krass
Unread 20-01-2005, 01:54
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Analog Input Trouble
The compiler doesn't seem to handle this very well. I've taken to just using a temporary variable for the return value of a function, then pass the value of the temporary variable into printf. Try this:
unsigned int temp_analog_value;
temp_analog_value = Get_Analog_Value(rc_ana_in01);
printf("Raw value: %u\n", temp_analog_value);
-Kevin
Kevin Watson
http://kevin.org
Unread 20-01-2005, 12:07
Matt Krass's Avatar
AKA: Dark Ages
I'll definitely try that, however once I get to robotics I won't have access to these forums, so in case it doesn't work out, does anyone have any other tips or things for me to check?
Thanks, Matt.
Matt Krass
Unread 20-01-2005, 12:23
Electrical Engineer
Rookie Year: 1995
Matt,
Remember that you are displaying in decimal. -1 = 0xFF which is full scale (>+5V input).... Are you sure it's not working?
Mike Betts
As easy as 355/113...
Unread 20-01-2005, 12:33
You might test on an alternate controller like the EDU or last year's RC.
I ran a quick test on the EDU with this year's 2.4 compiler and didn't have a problem. I tested with the Get_Analog call in-line and to a temp variable, and with the old printf and new 2.4 stdio.h printf. Same result though every time. 1023 with nothing on analog 1, 0 with the pins shorted.
Unread 20-01-2005, 12:35
Matt Krass's Avatar
AKA: Dark Ages
No matter what we do it remains at minus 1, so I don't think it's us not noticing. I'm about to go "borrow" the 2004 RC and see how it likes this, once I make sure we still have its master program. I'm hoping the code snippet above will solve my problems.
By the way, the accelerometer in the kit, could I use that with some decent math to imitate a gyro? Our budget is far too tight to get an Analog Digital gyro, or any other for that matter.
Matt Krass
Unread 20-01-2005, 12:42
Not really for a gyro. It's probably better used for distance or as a tilt sensor. It does make a great gravity detector.
Unread 20-01-2005, 13:25
FRC #2429
Matt,
I forgot to ask which version of the printf() function you're using? IFI's original or the version included with the 2.4 compiler?
-Kevin
Kevin Watson
http://kevin.org
Unread 20-01-2005, 16:11
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
You may also want to check that it's plugged in right, that it's the right port, etc. etc. Also check to see if an analog input defaults to high or low. (Since no ones mentioned it, I think.)
Unread 20-01-2005, 21:09
Matt Krass's Avatar
AKA: Dark Ages
Thanks for all teh help, it's working now. It was the printf statement.
Thanks guys, mods can close the thread if they want.
Matt Krass
Unread 20-01-2005, 13:13
FRC #2429
Thanks, Matt.
Matt,
To expand upon Mike's reply above, Get_Analog_Value() returns an unsigned int. Your printf() is expecting to manipulate an int because you used %d instead of %u. I fixed it in my code above, but forgot to mention it as another problem.
-Kevin
Kevin Watson
http://kevin.org
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Arm Design Input -- Four Bar Linkages Sachiel7 Technical Discussion 4 18-01-2005 01:29
Why not analog sensors?? gnormhurst Programming 16 07-03-2004 16:14
DC Motor current to an Analog Input junkyarddawg Motors 43 04-04-2002 15:53
