Go to Post IMHO if it was legal a peg leg would be better than a caster. - Edoc'sil [more]
Unread 20-01-2005, 19:11
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
using gas springs? needed?
in the past i've used gas springs to help dampen arm movements, and in some cases provide significant lifting force to help an arm lift hefty weights.
last year some of the great arm robots i saw weren't using any springs, i.e. kingman/cheesy poofs, and hotbot.
what is the professional opinion out there about this. is dampening needed? can a robust software solution make this mechanical solution obsolete? would a braking method like that used by Wildstang be enough? can the victors in brake mode supply some type of dampening?
the reason i'm so interested is that my last two arms worked well but the gas springs seemed to be more of a hassle than anything. now that i have access to some decent programming students and mentors i was hoping to phase them out all together. HotBot had a huge arm last year....no shocks or springs in sight!
any opinions are welcome. thanks.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 20-01-2005, 19:55
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: using gas springs? needed?
Sort of along the same lines, I have always wondered why lots of good teams do not use some sort of spring counterbalance on their arm. I can't seem to find a reason not to use springs to put your arm at "neutral buoyancy" so your drive motors have to do less work and you can lift more.
Team 1257
Unread 20-01-2005, 21:25
AKA: Anthony Lapp
anyone have a good reason for or against them?
Anthony Lapp
RobotOpen
Gas Springs Allowed ? Dave Garnett Pneumatics 6 20-01-2005 13:37
[OCCRA]: motor brush springs greencactus3 OCCRA Q&A 1 28-09-2004 20:56
Constant Force Springs - Data Sheets? Ben Piecuch Kit & Additional Hardware 1 06-05-2004 19:00
Boldly going where no team has gone before... archiver 2000 6 23-06-2002 23:42
