Go to Post I'm absolutely certain that kids prefer scoring points to not scoring points - AdamHeard [more]
Unread 22-01-2005, 11:40
kutty18 kutty18 is offline
#0234 (Cyberblue)
kutty18 is on a distinguished road
Send a message via AIM to kutty18 Send a message via Yahoo to kutty18
Encoder Hookup
Does anyone know what the left or right encoder's phase-A output is, and how do we wire up the 4 CA-3285-1FT Pin (supplied with encoders) into the Digital Input Panel? Thanks
Unread 22-01-2005, 11:47
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Encoder Hookup
A mechanical encoder typically has three pins: a phase A, a phase B, and a common. When wiring up an encoder to the RC, you would connect the phase A and phase B to two separate digital inputs, and then connect the common to +5. Optical encoders has a similar pinout, but with a connection for ground, too. Kevin Watson (http://kevin.org/frc) has an example of how to read an encoder in programming, but I'm guessing from the terminology that you used that you've already seen this code. I couldn't really understand what you were asking, but I hope that answers your question.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 22-01-2005, 11:58
#0234 (Cyberblue)
Re: Encoder Hookup
Thanks! We're using optical encoders, and they came supplied with a four-wire cable. At one end, the cable is attached to a miniature 4-pin. The four cables coming off of the pin are yellow, brown
(possibly maroon), blue, and orange. We are trying to figure out where these wires need to connect to. Any ideas?
A picture of our encoder is available at: http://www.usdigital.com/products/s4/
A picture of the cable is available at:
http://www.usdigital.com/products/co...in-micro.shtml
(It is the second picture, the CA-3285-(length)FT)
Unread 22-01-2005, 12:03
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Re: Encoder Hookup
See the picture on that first page? It says:
1: +5
2: A
3: -
4: B
Farther down the page, there is another picture and a table that reinforces this data. So, hook up two PWM cables to two different digital I/O pins (one should probably be one of the hardware interrupt pins, if you're using Kevin Watson's code). The reds go to pin 1, the blacks go to pin 3. One white goes to pin 2. One white goes to pin 4. On the other page, it shows you which side of the connector is pin 1, so you can identify which wire is which.
_
Unread 22-01-2005, 12:17
#0234 (Cyberblue)
Re: Encoder Hookup
Thank you very much! We really appreciate it. The thread can be closed, if needed.
Rotary Encoder (optical etc.) Gary C Technical Discussion 4 16-01-2005 18:23
encoder vs. motor stephenthe1 Programming 55 06-01-2005 22:07
Updated Encoder Code Available Kevin Watson Programming 2 04-01-2005 01:00
Choosing an Encoder for the Drive-train MikeDubreuil Electrical 11 21-10-2004 00:50
how to add steps in the provided encoder program for the edu Zaramel2002 Programming 3 11-02-2004 08:35
