Go to Post Learn the theory in the classroom and pick up the practical through clubs (FIRST, mini Baja, SAE)... you really need the scale balanced in the middle - Greg Needel [more]
Unread 23-01-2005, 14:23
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Pneumatic Piston Weight
We're looking at potentially using several 2" bore cylinders, some with 12" or 24" stroke, but I have many concerns regarding the unnegotiable weight these components add to the robot. I don't know, however, the actual weight of such components and I only have a nebulous idea from years past that they're really heavy.
I know that there was available somewhere information about the weight of pistons in the format (XX lbs. + YY lbs./in. stroke), but I can't find it anywhere. Can someone kindly point me to that information? Thanks.
--Madison--
...down at the Ozdust!
Unread 23-01-2005, 14:45
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: Pneumatic Piston Weight
I don't know the weight, but there is another issue you should be aware of because it sounds like a bad idea to me regardless of the weight. If I remember correctly, moving a single 2x24 cylinder once drains both your storage tanks almost entirely. If you plan to be using these with any frequency, you will run out of air.
Team 1257
Unread 23-01-2005, 14:48
Madison's Avatar
FRC #0488 (Xbot)
I'm quite aware of the other issues inherent in using these large pistons. I am interested in their weight so that I might see what I'm getting for money, so to speak, with respect to force exerted and component weight.
--Madison--
Unread 23-01-2005, 16:11
David Hoff's Avatar
David Hoff David Hoff is offline
FRC #4050 (Biohazard)
David Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to all
Last year Cyber Blue used 2'' bore pneumatics that had 24'' and 6'' strokes. Our weight database says that the 24'' was 5.22 pounds and that the 6'' was 2.52 pounds.
Cyber Blue Team 234: Indianapolis, IN 2002-2006
Purdue FIRST Programs: West Lafayette, IN 2006 - 2010
Cyber Titans Team 3793: Frederick, MD 2012
Biohazard Team 4050: Chambersburg, PA 2014
Unread 23-01-2005, 16:30
Madison's Avatar
FRC #0488 (Xbot)
Thanks, David. I saw this on your spreadsheet just a bit earlier and am now searching for similar information for 1.5" and 3/4" bore pistons.
For 2" bore pistons, this means that there's a base weight of 1.62 lbs. with an additional .15 lbs. for each inch of stroke.
--Madison--
Unread 23-01-2005, 18:46
Gary Bonner Gary Bonner is offline
FRC #3974
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
From the 2003 pneumatics manual:
Approximate weight calculations for custom cylinders, not including the rod clevis or pivot brackets:
3/4" Bore 0.21 lbs. + 0.03 lbs. per inch of stroke
1/2" Bore 0.73 lbs. + 0.08 lbs. per inch of stroke
2" Bore 1.62 lbs. + 0.15 lbs. per inch of stroke
Unread 23-01-2005, 19:01
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
http://www.bimba.com/pdf/bmol.pdf
Something to consider as well....
In our design we were considering using a number of large stroke pneumatics to pull up stages in a lift, and realized that we could reduce those stroke lengths significantly by using pulley systems, effectively using mechanical advantage.
The picture attached basically shows that by pulling the lower pulley down, it will require twice as much force, but make the other end of the string around the upper left pulley move twice as far (and twice as fast). Most pneumatics have much more force available then what you'll need, so this might be an effective way to reduce the required stroke lengths, if this is indeed your application.
If it's not, then maybe someone else will enjoy another addition to the collection of world famous art, aptly titled, "Art by Matt"
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Robot Weight Limit: Rule Conflict Specialagentjim Rules/Strategy 10 06-08-2005 17:52
Breaker Panel weight Emily Pease Electrical 4 24-01-2005 12:22
Robot Part Weight List Don Wright Technical Discussion 3 20-01-2005 12:55
How can i mount a pneumatic piston to a pvc pipe!?!?! archiver 2001 4 24-06-2002 01:11
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
