Go to Post You don't always get what you pay for, but you hardly ever get what you don't pay for. - MrForbes [more]
Unread 25-01-2005, 16:17
VideoMan053's Avatar
VideoMan053 VideoMan053 is offline
Computer Freak
AKA: Dan J.
FRC #0063 (Red Barons)
VideoMan053 is an unknown quantity at this point
Send a message via AIM to VideoMan053
Camera Tracking Woes
Has anyone been able to get the camera to track and follow (or get close to) one of the vision tetras?
I had an idea about having the drive motors try and turn so that the pan servo on the camera returns to zero, but that doesn't seem to be working.
I have something like this
if (cam.pan_servo < 127) // Camera is turned left
	 pwm01 = 70; // Left Drive Motor
	 pwm-2 = 200; // Right Drive Motor Forward
else
the code continues saying that if it is facing the other way, turn right.
Any ideas?
GET OVER IT! ~ not the most useful words in competitions, but some of the most useful in life!
My Jobs: Programming
Unread 25-01-2005, 18:48
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Camera Tracking Woes
It doesn't seem to be working, like...?
I think the default code is setup that the RC does tracking (which I think is a bad idea, since the camera is perfectly capable of it).
Unread 25-01-2005, 19:09
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
While that possibly can get the robot to drive towards the tetra, it probably won't work well.
The best way to accomplish this is to do it with some form of a control loop. In a control loop, you take as input where you'd like to be. You then subtract out where you currently are. Then, you transform this value (through a variety of techniques the simplest of which being a proportional) and output it to the motor.
In short this is:
output = transform(current position - desired position )
If you're using a proportional controller, it would be:
output = constant * (current position - desired position)
To get the robot to drive to the tetra, you want the pan position of the camera to center. That will give you the current position and the desired position. You can determine the constant through experimentation. There is a bit more to it given that for output, no movement is at 127 not 0. You also have to have a way to make sure it will still go forward when centered.
We used a very similiar technique last Saturday and the robot would reliably drive toward the tetra as long as the camera tracked it.
Matt
Unread 27-01-2005, 19:54
Computer Freak
AKA: Dan J.
Okay, does anybody know what the variable for the camera pan servo is in user_routines_fast.c ??? Please help!
Unread 29-01-2005, 18:09
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
If you look at the source code you will find that the variable is cam.servo_pan, unless I am mistaken.
[edit] It might be cam.pan_servo [/edit]
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
Camera Auto Tracking? Ryan Cumings Programming 9 22-01-2005 02:20
Game Field Camera Calibration Matthew_H Regional Competitions 2 15-01-2005 23:09
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
