Go to Post If you don't like getting tipped don't build a robot that tips. - Koko Ed [more]
Unread 28-01-2005, 16:21
hedgehogger hedgehogger is offline
hedgehogger can only hope to improve
Battery to RC problems
Hey all,
How can i connect the battery to thje rc since the connetors changed this year we found a way to connect the backup battery but cant find an adaptehr for the 12V thanks
-hedgehogger
Unread 28-01-2005, 16:26
cdawzrd's Avatar
cdawzrd cdawzrd is offline
Vice-President of Caffine
AKA: Jonathan
#0619 (CA Robotics)
cdawzrd will become famous soon enough
Send a message via AIM to cdawzrd
Re: Battery to RC problems
Originally Posted by hedgehogger
Hey all,
-hedgehogger
which battery, the main or the backup?
there is an adapter supplied for the 7.2v backup battery (small and blue).
You crimp a wire for the main connection, then run it to the power distribution board. Both ends are spade-type connectors this year (female end on the wire).
Cdawzrd
>> www.cdawzrd.com <<
>> www.carobotics.org <<
Battery To RC PROBLEMS hedgehogger Control System 1 26-01-2005 18:43
Why MUST the 7.2v battery be attached to operate servos on the RC? Mike Rush Control System 17 06-02-2004 18:57
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
connecting to the battery ahecht Technical Discussion 1 25-01-2002 17:15
