Go to Post ...your education can be interesting and even fun. If you look a little farther down the path, you WILL "use this crap", and "this crap" can even be cool if you know how to use it. - Chris Hibner [more]
Unread 31-01-2005, 14:29
SPARKY1688's Avatar
SPARKY1688 SPARKY1688 is offline
AKA: Marko Rajacic
FRC #1688 (StickShift)
SPARKY1688 will become famous soon enoughSPARKY1688 will become famous soon enough
wiring?
does any body have any pics on how they wired their motors to the speed controllers. Our chassis is using the kit bot and supplied gearbox 4 motors and 4 wheel drive. does anyone have any other diagrams except for the power distribution diagram?
Unread 31-01-2005, 14:31
D.J. Fluck
Posts: n/a
Re: wiring?
IFI Installation Guide for Victor 884 (PDF file)
Users guide PDF
Unread 31-01-2005, 16:00
Charly's Avatar
Charly Charly is offline
AKA: Ricardo Martins
#0714 (Super Panthers)
Team Role: Electrical
Charly is an unknown quantity at this point
Send a message via AIM to Charly
Re: wiring?
I think you misunderstood his question. He meant to ask about wiring a four-wheel drive robot. The manual doesn't explain how to wire the four victors with the motors for a four-wheel drive configuration.
Team 714 Robotic Design Captain/Electrician
Winners of the 2004 New Jersey Regional Chairman's Award!
Competitions we'll be attending in 2005: NJ Regional, Florida Regional, Championships!
Unread 31-01-2005, 17:32
zainali's Avatar
zainali zainali is offline
AKA: Syed Zain Ali
#1241 (Theory 6)
zainali is an unknown quantity at this point
Re: wiring?
The wiring of the other speed controllers to the motors will be exactly similar to the one CIM shown connected on the electrical layout diagram. All you have to do is to connect 3 more 40 Amps (to the top circuit breaker panel area, the one that has large spaced slots) and connect them to 3 more speed controllers. All the ground wires for the speed controllers obviously come from the ground pin area of the circuit breaker. You then just connect the speed controllers to a separate CIM motor (therefore 4 CIM with 4 Speed Controllers)
Hope this helps
Rick Hansen Secondary School
Team 1241
www.Theory6.org
GO LEAFS GO
Unread 31-01-2005, 17:44
ShorterBorder ShorterBorder is offline
#1562 (Robo Hobo)
ShorterBorder is an unknown quantity at this point
Re: wiring?
if you search for it im sure youll find one, i even found one!!!
LCD wiring to Program port jgannon Control System 10 30-01-2005 23:28
Neat & Organised Electric Wiring thoughtful Electrical 30 13-12-2004 22:46
Help wiring Line sensors magical hands Electrical 1 18-02-2004 10:17
Festo solenoid wiring? computhief263 Pneumatics 1 15-02-2004 12:25
Optical sensor wiring with the EDU Robot Geoffrey4283 Electrical 3 15-01-2003 21:03
