PRESSURE SWITCH
Quoted from the FIRST Pneumatics Manual:
Am I just way off track? |
Re: PRESSURE SWITCH
Re: PRESSURE SWITCH
Re: PRESSURE SWITCH
I thought it was 120 psi in the system not 115?
Re: PRESSURE SWITCH
It is 120...
Re: PRESSURE SWITCH
Rule R02, finally found it. Thanks
#7
Re: PRESSURE SWITCH
120 psi and 115psi are both correct....in a way:
The maximum allowed by the rules is 120psi. Your robot will be limited to 115 psi because the Nason Pressure Switch shuts off at 115psi. "The switches will open at approximately 115psi and will not close again until the pressure drops to approximately 95psi." from page 3 of : http://www2.usfirst.org/2005comp/Man...ticsManual.pdf |
#8
Re: PRESSURE SWITCH
"<R88> The Nason Co. pressure switch must be connected to the output end of one of the Clippard tanks to sense the tank’s pressure. The two wires from the pressure switch must be connected directly to a digital input and ground terminals on the Robot Controller, and the controller must be programmed to sense the state of the switch to operate the relay that powers the compressor." |
#9
Re: PRESSURE SWITCH
Re: PRESSURE SWITCH
Good info on this thread!
To follow-up: I'm sure teams are going to want to push the limit and get exactly 120 psi into their Clippards. 115 wont cut it - whether it be for practical reasons, or just out of principle =). I see two options here: 1) use only the Nason pressure switch, and code a timer that causes the compressor to run just long enough after the 115 psi cut-off to get roughly 120 psi. 2) connect both the Nason pressure switch AND the analog pressure sensor. Ignore the output from the pressure SWITCH, and use only the reading from the pressure sensor to dictate compressor shutoff at exactly 120 psi. Seems a littleweird to me, but are there other options here to get 120psi legally? -SlimBoJones... |
#11
Re: PRESSURE SWITCH
Re: PRESSURE SWITCH
We don't like the idea that we need to run the compressor at 95psi when only 60 is passed beyond the next gauge. If we code the "Start compressor with the Analog, we can run down the pressure to 60-65 and use the battery less... I think ![]() Last edited by phillutz : 02-02-2005 at 13:20. Reason: Additional text added |
#13
Re: PRESSURE SWITCH
Re: PRESSURE SWITCH
Re: PRESSURE SWITCH
Remember, you must connect the pressure relief valve when using the pump. This valve relieves pressure at around 120psi, no matter what! This is why it is legal to run your pump continuously.
Why pump up to 120 psi when you only use 60psi? That is a matter of "pressure volume". Let's say I have a cylinder that uses the exact volume of air that is in the tanks. If the pressure of the tank is only 60psi, then when I fire the cylinder once I expel all of the air in the tanks. If the pressure in the tanks is 120psi, then I have double the available air to use at 60psi. Air is compressible, which means as you increase the pressure the volume the same mass of air takes up gets smaller. Since the air tanks are a constant volume, when you increase the pressure then the amount of usable air increases. For this reason, you should try to maximize the pressure you have in the tanks. |
| Pneumatic pressure switch | M. Hicken | Programming | 9 | 29-01-2005 23:35 |
| Pressure Switch: Ordering a Spare | Bduggan04 | Pneumatics | 4 | 22-03-2004 20:15 |
| connecting pressure switch | kingpin3787 | Pneumatics | 2 | 19-02-2004 21:01 |
| spike for pressure switch? | Rob Colatutto | Rules/Strategy | 4 | 23-02-2003 15:42 |
| Error found in programming for the pump and pressure switch | sjharobotics | Programming | 4 | 06-02-2002 17:46 |
