Go to Post So take it all with a grain of salt, form your own opinions, lead by example, act responsibly, be graciously professional, and everything will be ok. - LauraN [more]
Unread 01-02-2005, 21:17
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Question A More Mobile Dashboard
I'm thinking about making/writing a dashboard setup that is a little more mobile (and a lot less pricey) than IFI's version. I'm thinking either a TI graphing calculator or an old PalmPilot Personal.
Has anyone tried this or similar? Success, failure? Was it easy? Should I buy a tablet PC instead?
[edit]Clarification: I mean a substitute for IFI's Dashboard program. Something that can connect to the dashboard port on the OI.[/edit]
Unread 01-02-2005, 21:24
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Re: A More Mobile Dashboard
One way you can start to make it more mobile is by making a portable power supply like Team 222 Tigertronics made. It can be found on the white papers. It's pretty much 3 9V batteries wired together into a special plug you can buy at radioshack. It works really well when you have to work in a place where it's hard to find a plug in like outside or somewhere in an empty place. It doesn't last very long since they're only 3 9V batteries, so i recommend getting some back ups too, but overall it's a really nice design and good job Team 222 and good luck. Wait...now i think about it, you mean the dashboard as the controller or the dashboard as on the computer when programming??? I may actually be totally wrong when I am talking about this, but if this is of no use to you, sorry.
-Jeff
Unread 01-02-2005, 21:34
AKA: Jamie Bliss
I mean the dashboard port on the OI.
Unread 01-02-2005, 21:38
Jeff K.'s Avatar
Hmm..now what?
Oh sorry, but if you ever need a portable power supply you can make one. Good luck on making a new dashboard.
Dashboard for .NET seanwitte Programming 8 16-02-2005 10:09
Poll:Use of Mobile Goals in This Year's Game MisterX General Forum 12 28-03-2004 23:10
Battery Voltages in Dashboard Ian W. Programming 10 07-03-2004 16:50
New dashboard packet spec Ameya Programming 2 08-01-2004 19:59
Dashboard Viewer Khalicl13 Technical Discussion 8 15-06-2001 23:36
