Backup autonomous code if a Radio Dropout Occurs
I was wondering if I could program some kind of autonomous code to kick in if we have a radio signal dropout. Would this work?
Re: Backup autonomous code if a Radio Dropout Occurs
It is a little disturbing when your r/c car hits a curb at 45-50 mph .Well, thinking about it, when disabled, do servos return to their center location? If not, they could be disabled when the radio signal is lost, but there is one servo for throttle and one servo for steering, so it would keep going at it's current speed and angle/turning degree which is what it does. Last edited by tkwetzel : 02-02-2005 at 18:05. |
You shouldn't have any problems with reception at competition; the signal is very strong and if it isn't, everyone's robots would be jerking around. That would be FIRST's fault, not yours. What were you doing when it dropped out? I haven't seen the radio drop out at all when we were doing anything. |
Nitro cars don't necessarily have a brake, they just sort of slow down...slowly until they're at a full stop, but probably the servo you had just left it at the position it was at before because I know that there is supposed to be a spring or something like that that releases the throttle and brings the servo back to neutral, so maybe the spring that was in your car had fallen out...I dunno...I may be totally wrong. But nitro cars are cool. What size is yours, 1/8, 1/10? |
#8
You Can also program in a "heart beat" that shuts down the bot after radio connection is lost
| Team THRUST - Kevin's Code and Camera Code Combine | Chris_Elston | Programming | 3 | 31-01-2005 22:28 |
| heres the code. y this not working | omega | Programming | 16 | 31-03-2004 15:18 |
| variable? | manodrum | Programming | 11 | 01-04-2003 17:20 |
| autonomous mode problem on field | Chris_C | Programming | 17 | 26-03-2003 19:11 |
